BBB without ethernet
can the BBB board manufacturer remove the ethernet RJ45 connector?
i need it for may device.
i will use ethernet extension for debug use at the lab. but for productioni don’t need it…
If you need it removed, you can take the open source material and build it yourself. We are not in a position to build 1 off boards.
What about a manufacturer who purchases BBs in quantity?
I am sure that could be arranged if the quantities are enough.
