My BBB won’t boot now when it tries to mount the root device. I must have copied some file from another BBB and messed up something.
My guess is the /etc/fstab and /boot/uboot/uEnv.txt files. Are there others?
I have tried using the BBB-eMMC-flasher-debian-7.2-2013-11-15.img, but I still get the same problem after removing the sdcard and repowering up the BBB.
What is the best way to recover from this?
Just remove all files on the eMMC partitions?
Other?
Please retry with the latest:
http://elinux.org/BeagleBoardDebian#eMMC:_BeagleBone_Black
There's been a few changes since 2013-11-15
Should also mention, just those two files..
You can use this image as a recovery..
http://elinux.org/BeagleBoardDebian#BeagleBone
Just remember to hold down the boot button..
Then using
lsblk
ls -lh /dev/disk/by-uuid/
fix both
uEnv.txt (on /dev/mmcblk1p1 ) & /etc/fstab (on /dev/mmcblk1p2)
Update:
Mr Nelson confirmed my thoughts and provided a means to fix:
You can use this image as a recovery…
Just remember to hold down the boot button…
Then using
lsblk
fix both
Also, using a newer image for the flasher image fixed it also.
Brad
