Today I’ve flashed my BBB rev B with Debian 7.5 (went quicker than the described 45 minutes). After playing with the network settings I wanted to reboot “shutdown -r now”, when I did that the BBB did not came up anymore… Only the power led is on, other USR leds are not on, whatever I try (holding boot, power button, reset button, …).
After a while I connected the Serial Debug cable and I’m seeing the following message.
.\�(kR֨�[X��(V,�#�Y.�,.H�YX�Z�,�Z[X��SI��,�Y�k R�&.HK�KLC���$HQ��CR ### Please RESET the bcard ###
C�UK��,�TS��014.04-00014-c43880f5 (Apr 22 2014 - 132354)
�YX�Z�,�X���C�.[(kR֨�[X��(V,ר�.#HY��cr readinc imace arcs, err - -1
readinc 5-bcc4.imc
.\�(kV֨�[X��(V,�#�Y.�,.H�YX�Z�,�Z[X��SI��,�Y�k R�&.HK�KLC���$HQ��CR ### Plea3e RESET 4he bcard ###
�YX�Z�,�X���C�.\�(kR֨�[X��(V,Ө�&#HY��cr readinc imace arcs, err - -1
readinc 5-bcc4.imc
.\�(kR֨�[X��(V,�#�Y.�,.H�YX�Z�,�Z[X��SI��,�Y�k R�&.HK�KLC���$HQ��CR ### Plea3e RESET the bcard ###
C�UK��,�*TS��014.04-00014-c43880f5 (Apr 22 2014 - 132354)
�YX�Z�,�X���C�.\�(kV֨�[X��(V,Ө�&#HY��cr readinc imace arc3, err - -1
readinc 5-bcc4.imc
.\�(kR֨�[X��(V,�#�Y.�,.H�YX�Z�,�Z[X��SI��,�R�k R�&.HK�KLC���$HQ��CR ### Plea3e RESET the bcard ###
Only when pressing the RESET button I’m receiving feedback, however the same as above.
Googling did not bring me to any relevant topics so I tried the following without luck
- Boot from SD
- Re-flash emmc
- power over USB or 5VDC
Would be good to see if anyone else saw this before and/or has a solution to this.
Michaël
