I have a 16GB microSDHC card (from an old blackberry) inserted and the BBBlack won’t boot, just hangs with 3 of the 4 LEDs on.
Serial debug messages:
U-Boot SPL 2013.04-rc1-14237-g90639fe-dirty (Apr 13 2013 - 13:57:11)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-rc1-14237-g90639fe-dirty (Apr 13 2013 - 13:57:11)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
Hit any key to stop autoboot: 1 … 0
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
** Unable to read file uEnv.txt **
** Invalid partition 2 **
U-Boot#
This is without the S2 button being pressed.
With S2 being pressed:
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
I2C: ready
DRAM: 512 MiB
0 MiB
cpsw, usb_ether
micro SD card found
reading uEnv.txt
U-Boot#
Keeps trying to look for the uEnv file on the SD card I just installed.
