BBB's memory is messy?
Hi, all:
Sorry for dropping this stupid question. But, with my TF card plugged in, I checked the memory of BBB (Refer to the bottom command)
It looks BBB’s memory is quite messy.
On my 32Giga TF Card, namely, mmcblk0, I got /dev/mmcblk0p1 and /dev/mmcblk0p2
On eMMC, namely, /dev/mmcblk1, I got dev/mmcblk0p1, dev/mmcblk0p2, /dev/mmcblk1boot0, and /dev/mmcblk1boot1 .
Just wondering, why on eMMC, there are /dev/mmcblk1boot0, and /dev/mmcblk1boot1? What for?
And, it looks that my eMMC is only of 2Giga? I was thinking the newest BBB is of 4Giga eMMC???
Cheers
Pei
  1. debian@beaglebone:~/Downloads/installed/kernel$ ls -ls /dev/mmcblk*
0 brw-rw—T 1 root floppy 179, 0 Apr 15 00:17 /dev/mmcblk0
0 brw-rw—T 1 root floppy 179, 1 Apr 15 00:17 /dev/mmcblk0p1
0 brw-rw—T 1 root floppy 179, 2 Apr 15 00:17 /dev/mmcblk0p2
0 brw-rw—T 1 root floppy 179, 8 Apr 15 00:18 /dev/mmcblk1
0 brw-rw—T 1 root floppy 179, 16 Apr 15 00:17 /dev/mmcblk1boot0
0 brw-rw—T 1 root floppy 179, 24 Apr 15 00:17 /dev/mmcblk1boot1
0 brw-rw—T 1 root floppy 179, 9 Apr 15 00:18 /dev/mmcblk1p1
0 brw-rw—T 1 root floppy 179, 10 May 29 02:16 /dev/mmcblk1p2
  1. debian@beaglebone:~/Downloads/installed/kernel$ fdisk -ls
Disk /dev/mmcblk0: 31.5 GB, 31486640128 bytes
4 heads, 16 sectors/track, 960896 cylinders, total 61497344 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x000a9bd0
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 * 2048 198655 98304 e W95 FAT16 (LBA)
/dev/mmcblk0p2 198656 61497343 30649344 83 Linux
Disk /dev/mmcblk1: 1920 MB, 1920991232 bytes
4 heads, 16 sectors/track, 58624 cylinders, total 3751936 sectors
Disk identifier: 0x00000000
/dev/mmcblk1p1 * 2048 198655 98304 e W95 FAT16 (LBA)
/dev/mmcblk1p2 198656 3751935 1776640 83 Linux
Disk /dev/mmcblk1boot1: 1 MB, 1048576 bytes
4 heads, 16 sectors/track, 32 cylinders, total 2048 sectors
Disk /dev/mmcblk1boot1 doesn’t contain a valid partition table
Disk /dev/mmcblk1boot0: 1 MB, 1048576 bytes
Disk /dev/mmcblk1boot0 doesn’t contain a valid partition table
From eMMC spec 4.3, eMMC will have 2 boot partition called boot partitions , and general partition called user partition
For robust disign , Boot partition will not be able to use wear leave . so it should be use as SLC design (against user partition MLC )and make a backup
And on Ti chip , these 2 partition CAN NOT used as boot partition , while in FSL and QUANTUM , their boot rom can boot from these 2 (only depend on the boot flag in extCSD[179])
You can read the imx 6 Reference manual for more detail about this .
