Progress:
The error I struck using grow_partition.sh was:
Re-reading the partition table …
sfdisk: BLKRRPART: Device or resource busy
sfdisk: The command to re-read the partition table failed.
Run partprobe(8), kpartx(8) or reboot your system now,
before using mkfs
sfdisk: If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes: dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
I rebooted and ran:
root@beaglebone:/opt/scripts/tools# ./version.sh
git::[e066cb50c5eda24ce09227b1a155da823d56225a] eeprom:[A335BNLTBWA51646BBWG0358] dogtag:[BeagleBoard.org Debian Image 2017-02-12] bootloader:[/dev/mmcblk0]:[U-Boot 2017.03-rc1-00003-ga09f2d] bootloader:[/dev/mmcblk1]:[U-Boot 2016.11-rc3-00002-g73df7f] kernel:[4.4.48-ti-r88] nodejs:[v4.7.3] root@beaglebone:/opt/scripts/tools# df Filesystem 1K-blocks Used Available Use% Mounted on udev 10240 0 10240 0% /dev tmpfs 99956 3036 96920 4% /run /dev/mmcblk0p1 7376168 2934944 4090164 42% / tmpfs 249884 4 249880 1% /dev/shm tmpfs 5120 4 5116 1% /run/lock tmpfs 249884 0 249884 0% /sys/fs/cgroup tmpfs 49980 0 49980 0% /run/user/1000 root@beaglebone:/opt/scripts/tools# fdisk -l /dev/mmcblk0 Disk /dev/mmcblk0: 7.2 GiB, 7744782336 bytes, 15126528 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xc9171f1a Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 * 8192 15126527 15118336 7.2G 83 Linux I HAVE NOT RUN mkfs. ??? So there is only one partition BUT it starts at 8192 sectors. Is there absolutely nothing pior to 8192 sectors? Is there a MRB in the first 512 bytes? If I used dd in linux must I allow for that? Why so many sectors (8192)? The version is: bootloader:[/dev/mmcblk0]:[U-Boot 2017.03-rc1-00003-ga09f2d] Is U-Boot 2017.03-rc1-00003 sufficiently up to date? This is how my slots are at present: 0: P—L- 0 4D 7.0 LCD CAPE- 4DCAPE-70T ,00A3,4D SYSTEMS ,BB-BONE-LCD7-01 1: PF---- -1 2: PF---- -1 3: PF---- -1 In /boot/uEnv.txt I uncommented: enable_uboot_overlays=1 and disable_uboot_overlay_video=1 Moved /uEnv.txt to /uEnv.txt.old I shutdown the BBBW and it actually shutdown not rebooted??? After so long faulty? After restart checked slots which was the same as above. In /boot/uEnv.txt I uncommented:disable_uboot_overlay_audio=1 In /boot/uEnv.txtadded cape_enable=bone_capemgr.enable_partno=BB-UART1,BB-I2C1,BB-UART4 I shutdown the BBBW but it rebooted. New slots: 0: P—L- 0 4D 7.0 LCD CAPE- 4DCAPE-70T ,00A3,4D SYSTEMS ,BB-BONE-LCD7-01 1: PF---- -1 2: PF---- -1 3: PF---- -1 4: P-O-L- 1 Override Board Name,00A0,Override Manuf,BB-UART1 5: P-O-L- 2 Override Board Name,00A0,Override Manuf,BB-I2C1 6: P-O-L- 3 Override Board Name,00A0,Override Manuf,BB-UART4 I tried adding BB-ADC with no effect. BB-BONE-LCD7-01 uses some of AIN pins. AIN0 to AIN3? Not sure. root@beaglebone:/home/debian# cd /sys/bus/iio/devices/iio:device0 root@beaglebone:/sys/bus/iio/devices/iio:device0# ls -al total 0 drwxr-xr-x 5 root root 0 Feb 20 23:41 . drwxr-xr-x 4 root root 0 Feb 20 23:41 … drwxr-xr-x 2 root root 0 Feb 21 03:49 buffer -r–r--r-- 1 root root 4096 Feb 21 03:49 dev -rw-r–r-- 1 root root 4096 Feb 21 03:49 in_voltage4_raw -rw-r–r-- 1 root root 4096 Feb 21 03:49 in_voltage5_raw -rw-r–r-- 1 root root 4096 Feb 21 03:49 in_voltage6_raw -rw-r–r-- 1 root root 4096 Feb 21 03:49 in_voltage7_raw -r–r--r-- 1 root root 4096 Feb 21 03:49 name lrwxrwxrwx 1 root root 0 Feb 21 03:49 of_node → …/…/…/…/…/…/firmware/devicetree/base/ocp/tscadc@44e0d000/adc drwxr-xr-x 2 root root 0 Feb 21 03:49 power drwxr-xr-x 2 root root 0 Feb 21 03:49 scan_elements lrwxrwxrwx 1 root root 0 Feb 21 03:49 subsystem → …/…/…/…/…/…/bus/iio -rw-r–r-- 1 root root 4096 Feb 20 23:41 uevent root@beaglebone:/sys/bus/iio/devices/iio:device0# I guess from the above I can use AIN3 to AIN6? The important result is that using uboot overlays does NOT impact on wireless. Regards, Kevin.
