I am using a Beaglebone Green and I need to start my device from sd instead from firmware on eMMC.
I need to use pins assigned by default to eMMC, so i disabled uboot overlays about eMMC in uEnv.txt file.
When I insert a new sd card to boot system from it, I see the Beaglebone to install a new firmware on the eMMC, i suppose… Leds D2-D3-D4-D5 light syncroniusly every time I restart the system, and it takes about 10 minutes to be ready.
What should I see?
Unitil now, I am communicating with BBG using the USB port on card and a serial terminal on my computer.
There are some news:
I have inserted a sd card, flashed with an image of the same debian version and with an update of uEnv.txt file (I just uncommented the line “#disable_uboot_overlay_emmc=1”);
If I turn on BBG, the leds on it remain turned on. What it means?
I attach a video.
Is there a guide to follow to set by default the booting from sd card and ignore eMMC using the pins dedicated to it?
