Make BBGW boot kernel 3.8
The second option seems to be easier, and might have been done here but I am not sure how…
I tried to boot a 3.8 image or downgrade to 3.8 from latest image, edit uEnv.txt to use ‘am335x-bonegreen-wireless.dtb’ but it does not work (hangs on “Uncompressing Linux… done, booting the kernel.”, see this log)
I am sure that I should edit the dts file before compiling it to dtb, but I don’t know how. Do you have any suggestion or documentation to start from ?
Small update, I tried to use the script “./update_kernel.sh --bone-channel --stable”.
It starts to boot but give an error I am not able to understand, if somebody can help : “Unhandled fault: external abort on non-linefetch (0x1008) at 0xe0858000”
Ok thanks, I understand what happens now. Did you had time to test it ?
I wanted to do it by myself but I did not find the 3.8 branch of your repository
Indeed, but I tried to avoid porting BeagleLogic (logic analyser) kernel patches to v4
I might try if their is no other option. But could you please point me to some doc explaining why wlan can not be used ?
Or just use v4.4.x-bone as that supports uio_pruss out of box like 3.8.13
I will try but this set of patches you applied on 3.8 need to be updated…might not be easy for me but a good way to learn !
“I” don’t care enough about 3.8.13 to backport all the wlcore/wl18xx
changes needed for 3.8.13.
