The system appears to fail during boot. This has worked for a long time on the BBB and I’m trying to move a running application to the BBGW.
root@bbgw:/home/cd5# uname -a
Linux bbgw 4.4.38-bone-rt-r14 #1 PREEMPT RT Mon Dec 12 10:10:25 UTC 2016 armv7l GNU/Linux
I have also tried to use config-pin, but I haven’t been able to find any documentation that will allow me to work through the problems.
For example:
cd5@bbgw:~$ sudo ./config-pin P8_18 low
P8_18 pinmux file not found!
cape-universala overlay not found
run “config-pin overlay cape-universala” to load the cape
That cape does work on the Beaglebone green. However, the Beaglebone green, and Beaglebone black both have ethernet, where the Beaglebone green wireless has a wifi network interface. So, this is an assumption but here are two points of contention:
Since the BBGW has wifi and the Beaglebone black has ethernet it could be failing because of a networking interface conflict.
Since all Beaglebone have an EEPROM that when flashed properly hold a board identification string" The board file you’ve chosen may fail to load at boot.
With that said, it’s going to be more complicated than that. As the files for the BBB will probably not have the proper network interface configuration for the wireless interface: ethernet versus wireless. So I’m fairly sure just adding the #include would not work. However . . . it may be possible that https://github.com/RobertCNelson/dtb-rebuilder/blob/4.4-ti/src/arm/am335x-boneblack-wireless-emmc-overlay.dts would work. I’d double check with Robert first however. To make sure nothing bad would happen. I wouldn’t think so, but thats what I think, and not what I know as fact.
Additionally, this is a reason for you to buy a serial debug cable, or module. With such a device, you’d probably know exactly why the board fails to boot, or at minimum have a really good idea based on uboot output.
I learned by doing. But there are several docs on the web covering it.
Personally I found the documentation on the web counter intuitive though. I
felt it was holding me back. So one day I just dove in, and everything
started making sense. Granted at that point I had 3+ years hands on with
the hardware. A little here, and there.
If you've been programming for any amount of time, reading through an
overlay while you may not know specific details, should make sense. In
fact, if you toss a device tree file into an editor with syntax
highlighting, and select C as the language. You get syntax highlighting too
Anyway, there is a document by Panto, and Tom King in PDF format called
something like " kernel 3.8 and device tree". Should come up in the top of
a google search list. IN fact: http://elinux.org/BeagleBone_and_the_3.8_Kernel
Just keep in mind that there would be some differences for the newer
kernels . . . but the gist should be nearly the same.
Your intuition seems to be very good. After much testing, I now can see that as soon as I enable “dtb=am335x-boneblack-emmc-overlay.dtb” and reboot, the system does come up but wlan0 is no longer known. By that I mean that “ifconfig -a” and “connmanctl technologies” both fail to list it. The odd thing is that having setup wlan0 with connmanctl, it does come up and run and I can login (although it may quit after awhile).
Yes, I can read the dts files fairly easily. The problem is knowing which overlays are included for a given device.
Between the problems mentioned above and the failures that I’m seeing trying to use config-pin to setup the gpios, I guess I’m wondering if there is anyone who is actively working on getting the BBGW DT running. This is supposed to be a simple port of an existing application to the BBGW because we don’t need hdmi and would like to add wifi. Of course, the desire is to reduce cost as well.
If there is anyone working on the DT issues for the BBGW, I would appreciate a note. If I don’t hear soon, I will simply recommend that we move to the BBBW instead.
My understanding that the two boards, BBGW and BBBW both use the same
wireless radio. I have not looked into that personally, because I do not
own either one. But assuming that were fact, I'd probably try using the
BBBW wireless board overlay. Because I do have hands on using the same
overlay you mentioned in your first post, on several beaglebone greens. The
reason why it works, is that the beaglebone green has no HDMI framer, and
that overlay disables HDMI video, and audio.
You'd need git installed, then just git clone that whole repo( not just
that one file ), then . . .
cd into the working directory
make
make install
To test it. If I had a BBGW wireless I'd test it myself before hand. But I
don't . . . Also keep in mind that I'm not 100% sure that overlay won't
damage your board, but I really do not see how it could . . . which is why
I'd dive right in myself if I had the hardware in hand.
I found this post in googgle searches as I am trying to do the same thing. I want to enable P9_28 to P9_31 as gpio. If I go normal HDMI Overlay disable method, wifi stops working. Were you able to find a solution for this that both SPI1 pins and Wifi works together in BBGW. I would be great if you can please share with me your findings.
