I have a SDcard with lastest debian image for BBIA.
If I plug the sd card and connect the USB Cable, the power led is on and all other leds are off.
If I unplug the usb, remove sd card and connect the usb cable the board is working fine, if I plug the sdcard I can mount and see the filesystem.
What size uSD card are you using and how are you powering the board? I’ve had issues trying to power the AI from a PC USB port and found a power adapter or powered USB hub with the proper power specs works best.
Is a 16GB sandisk - I tried 3 different cards.
I powered by USB, power adapter - I have from a RP4 and a power bank too.
In true I bought 2 from farnell and the first one the sd slot is dead - and this second one is with this problem - even with power issues the user leds should blink or show something in the console.
Hi. I ran into a similar problem where I needed to put the program on the eMMC and use an SD card to store the data. But when I insert an empty SD card, the board card cannot boot the system from eMMC
