to drive my external 2.5" hd connected to my BBW I bought a powered
USB-HUB (USB3.0 compatible with USB2.0).
Connected to the USB-HUB are a KBTalking Pure60% keyboard, a
TOSHIBA stor.e HD (500GB) and a Perixx Peripad touchpad.
When booting the system I do as follows:
- power on the USB-HUB which spins up the HD
- power on the Beagle Bone White
Everything works fine...except that the keyboard does not wake
up (the CapsLock key is connected to a LED. Pressing Caps Lock
does not lit up the LED in this state).
Diconnecting and reconnecting the keyboard fixes that.
Using another unpowered hub which does not talk to my HD does
not show this problem.
Connecting the keyboard directly to the BBW also is working fine.
Is there any way to fix that or any workaround besides buying another
USB-HUB (which would be the third then)?
Best regards,
mcc
