I had problems getting cross compile to work.
The kernel needed for ti graphics was different than the linaro toolchain, so my cross compile failed even when I specified sysroot as the SD card.
So, I built the whole thing on the beaglebone.
To develop applications, I installed QT Creator on a x86 32bit debian image, developed the application for the desktop, copied the project to the beaglebone and compiled it there.
Here’s how I set up my qt 5.3.2 production image:
install base image: bone-debian-7.6-console-armhf-2014-09-04-2gb.img on a SD card
Put the SD card in your beaglebone and boot to the SD card
Log in
Change the default password
Enter the following (things to type at the console will start with #, don’t type the #)
#passwd
Upgrade the image to latest repositories
#sudo apt-get update
#sudo apt-get upgrade
Install the kernel that works with ti graphics SDK
#sudo apt-get install linux-image-3.14.19-ti-r27
#sudo reboot
Set up your locale information
#sudo apt-get install locales
#sudo dpkg-reconfigure locales
Install network date/time sync
#sudo apt-get install ntpdate chrony
Install touch screen drivers + utilities like ts_calibrate
#sudo apt-get install tslib libts-bin
Install wireless drivers & tools for USB wireless dongle
#sudo apt-get install wireless-tools wpasupplicant
Install pre-requisite for installing ti graphics SDK
#sudo apt-get install lsb-release
Configure wireless to start when system starts
by uncommenting wireless entries
#sudo nano /etc/network/interfaces
auto wlan0
iface wlan0 inet dhcp
wpa-ssid networkname
wpa-psk passphrase
Configure time zone and touch screen environment variables
by appending the following values
#nano .profile
export TZ=‘America/Chicago’
export TSLIB_CONSOLEDEVICE=none
export TSLIB_CONFFILE=/etc/ts.conf
export TSLIB_CALIBFILE=/etc/pointercal
export TSLIB_TSDEVICE=/dev/input/event1
export TSLIB_FBDEVICE=/dev/fb0
export TSLIB_PLUGINDIR=/usr/lib/arm-linux-gnueabihf/ts0
export TSLIB_TSEVENTTYPE=INPUT
The LCD cape will be disabled - you will need to add the following to
re-enable the LCD cape and disable the HDMI
#sudo nano /boot/uEnv.txt
fdtfile=am335x-boneblack-4dcape-43t.dtb
cape_disable=capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN
#sudo reboot
Now, switch over to a debian 7.6 x86 32 bit linux box
Load pre-requisites for building ti graphics SDK and build it for the kernel
#sudo apt-get install git build-essential device-tree-compiler lzma lzop u-boot-tools libncurses5-dev
#git config —global user.name “name”
#git config —global user.email “email”
#git clone https://github.com/RobertCNelson/ti-linux-kernel-dev.git
#cd ti-linux-kernel-dev
#git checkout 3.14.19-ti-r27
#./build_kernel
#./sgx-build-modules.sh
Copy the compiled ti graphics SDK to the beagle bone
#scp ./release/GFX_5.01.01.01.tar.gz debian@196.168.1.???:~/.
Run the following on your beagle bone
#sudo tar xfv GFX_5.01.01.01.tar.gz -C /
#cd /opt/gfxinstall/
#sudo ./sgx-install.sh
#sudo reboot
Verify the ti graphics SDK installed
After running this line you should see the following output
#lsmod | grep omap
omaplfb 13161 0
pvrsrvkm 178957 1 omaplfb
tilcdc 28310 1 omaplfb
Run a demo to make sure it all works
#cd /opt/gfxsdkdemos/ogles2
#sudo ./OGLES2ChameleonMan
Exit the demo
#q
Shut down
#sudo shutdown now
Power down and insert the SD card into the Linux box
Make a backup of the SD card on the Linux box
#sudo dd if=/dev/sdb bs=1M | gzip > ./debian-7.6-GFX-WIFI-base.gz
Eject the SD card and insert it back in the beaglebone and boot to SD Card
Log in
Execute the following:
#sudo /opt/scripts/tools/grow_partition.sh
#sudo reboot
Copy the qt dev files to the beaglebone from the linux box
#scp qt-everywhere-opensource-src-5.3.1.tar debian@192.168.1.???:~/.
Execute the following on the beaglebone
#sudo apt-get install make gcc g++ alsa libasound2-dev libgles2-mesa-dev mtdev-tools libmtdev-dev libudev-dev
#tar xfv ./qt-everywhere-opensource-src-5.3.2.tar
#mv qt-everywhere-opensource-src-5.3.2 qt-src
#mkdir qt-beagle
#cd qt-beagle
#…/qt-src/configure -v -opensource -confirm-license -prefix /usr/local/qt-5.3.2 -no-largefile -qt-zlib -qt-libpng -qt-libjpeg -no-nis -no-cups -opengl es2 -no-xcb
#make
Wait about 16 hours
#make install
Copy the qt deployed image for future use
#tar -cvzf qt-5.3.2.tgz /usr/local/qt-5.3.2/
Copy the qt-5.3.2.tgz to the linux box
Shutdown the beaglebone and move the SD card back to the linux box
On the linux box,
Restore the base graphics image we saved before
#sudo gzip -dc ./debian-7.6-GFX-WIFI-base.gz | sudo dd of=/dev/sdb
Eject the SD card and insert it in the beaglebone and boot to SD card
Copy the qt libraries to the beaglebone
#scp qt-5.3-libs.tar.gz debian@192.168.1.???:~
On the beaglebone, execute the following:
#sudo tar xfv qt-5.3-libs.tar.gz -C /
#sudo nano /etc/environment
export QT_QPA_PLATFORM=eglfs
export QT_PLUGIN_PATH=/usr/local/plugins
#nano /etc/profile
export PATH=$PATH:/usr/local/qt-5.3.2/bin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/qt-5.3.2/lib
#sudo apt-get install dbus libpng12-0 libglib2.0-0 mtdev1 libfontconfig1 libts-bin libgles2-mesa-dev mtdev-tools libasound2
#sudo reboot
Your deployment system should be ready to go.
Try running some qt examples.
To build qt applications, install QT Creator on your linux box and qt 5.3.2
Build for the local desktop.
Copy the project to the beaglebone and compile it there when you are ready to test on the beaglebone.
