Hi All,
I am working on Beagle board B7. I am trying to port Angstrom Linux on my board. But recently my NAND boot loader crashed and now I am trying to boot from SD card. I copied MLO, u-boot.bin, uImage to first partition and Angstrom file system second partition. After copying I connected my board to PC using serial cable and accession through minicom. When I powered up the board it just displaying 40V and followed by some junk characters. Even I hold down USER button for some time but still it is not booting. Can any body suggest how could i solve this problem.
NaveenKumar,
Hi All,
I am facing the same problem, no SD access and corrupt NAND.
I am trying to recover from UART or USB as we will not have SD access
until we restore u-boot, i think.
http://elinux.org/BeagleBoardRecovery#UART_recovery
I think we have to load u-boot from SDRAM but i don't know how to do that, yet.
good luck for us,
s
julio menezes
vjvargas,
thx by your replay.
In this case, NAND is corrupted and we do not have SD card access,
even with User pressed.
It is an unusual situation.
I think we have to recover booting thru UART or USB x-loader and
loading u-boot from SDRAM, am i right ?
regards,
julio menezes
Thanks for reply. What ever you suggested that I have already tried. After powered On the board on minicom console it displaying like 40V and some junk characters. I hold down the user button while pressing reset button for 1 min but even there is nothing coming in console means it is not booting. Any other way to solve this issue…
I will also try booting from UART. Please let me know if u solve this problem so that I will follow same.
I have not solved it yet.
I am a litle bit onfused.
take a look at this page:
http://elinux.org/BeagleBoard#USB_boot
that is what i am trying.
regards,
julio menezes
#See USB_Boot for a patch to x-loader to boot all the way to Linux via USB.
#You can use USB boot utility together with U-Boot V2 and then use
U-Boot V2's loadb to load U-Boot (V1). Binary: U-boot V2
#Note: USB download can only load programs into OMAP3's internal SRAM.
This is 64k, so too small for U-Boot (V1). But unfortunately, U-Boot
V2 currently lacks NAND support. So we have to use:
# USB download -> U-Boot V2 (SRAM) loadb -> U-Boot (V1) (SDRAM) NAND erase
# For this, get usbload and U-Boot V2 using above links, start usbload
tool at PC and while ... plug in USB OTG (power) cable. At host, this
will result in:
wget http://members.efn.org/~rick/pub/x-loader-usb.tar.bz2
git clone git://git.denx.de/u-boot-v2.git
Hi
Check the power supply ,I had a case of power supply more than 5.1V ,and the pmu wil auto protect
You can try to power with usb otg , Just for verify .
Hope to be helpful
2012/9/26 julio menezes <yjmenezes@gmail.com>
You can try to format with HP format tools version 2.06 , this always work for my board
2012/9/27 liyaoshi <liyaoshi@gmail.com>
Finally I done booting Linux on my Board. The way I followed is I created one FAT32 partition and made it as bootable. In fdisk tool by pressing ‘a’ we can make the partition as bootable.
http://code.google.com/p/beagleboard/wiki/BeagleboardRevC3Validation
download the following list of files adn copy to SD card.
After copying, Insert the SD card, Hold down the USER button then power ON the board. This is the way I followed to bring the board Up. I hope this info useful to you.
NaveenKumar
I am happy you boot your BB.
one FAT32 partition and made it as bootable. In fdisk tool by pressing 'a'
Google Code Archive - Long-term storage for Google Code Project Hosting.
Please, could you post your fdisk ?
My fdisk starts at 63, and not 1 and i have tested with boot flag on too:
root@gnu-00:/home/jmenezes# fdisk /dev/sdb
Comando (m para ajuda): p
Disco /dev/sdb: 1977 MB, 1977614336 bytes
255 heads, 63 sectors/track, 240 cylinders, total de 3862528 setores
Unidades = setores de 1 * 512 = 512 bytes
Identificador do disco: 0x0004fac7
Dispositivo Boot Início Fim Blocos Id Sistema
/dev/sdb1 63 106495 53216+ c W95 FAT32 (LBA)
/dev/sdb2 112455 3855599 1871572+ 83 Linux
thx,
best regards,
julio menezes
NaveenKumar / all,
I format a new 8GB SD
Disco /dev/sdb: 7948 MB, 7948206080 bytes
255 heads, 63 sectors/track, 966 cylinders, total de 15523840 setores
Identificador do disco: 0x00000000
/dev/sdb1 * 63 144584 72261 c W95 FAT32 (LBA)
/dev/sdb2 144585 7807589 3831502+ 83 Linux
Copying MLO ... to /dev/sdb1 and
Booting with User pressed a get:
Texas Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24)
Reading boot sector
Loading u-boot.bin from nand
ECC Failed, page 0x00080400
8 30 83 a2 0 0 83 a5 5c 20 9f a5 5c 30 9f a5 0 20 83 a5 8 30 83 a2 0
20 83 a5 8 30 83 a2 0 20 83 a5 3f 3e 83 a2 0 20 83 a5 8 30 83 a2 0 20
83
40W�H�H�U���ᅁInstruments X-Loader 1.4.2 (Feb 19 2009 -
12:01:24)
Reading boot sector
My NAND is corrupted.
1- How do you fix your NAND ?
2- Have you used fdisk type c W95 FAT32 (LBAc W95 FAT32 (LBA)) ?
3- Does your first partition starts from 1 ?
thx,
best regards,
julio menezes
