Hi All,
I have tried to install Angstrom linux according to http://elinux.org/BeagleBoardBeginners. But after booting some extent it is hanging. Booting messages are
Texas Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24)
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2011.09-dirty (Oct 24 2011 - 23:56:08)
OMAP3530-GP ES3.1, CPU-OPP2, L3-165MHz, Max CPU Clock 720 mHz
I2C: ready
DRAM: 256 MiB
WARNING: Caches not enabled
NAND: 256 MiB
MMC: OMAP SD/MMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Beagle Rev C4
timed out in wait_for_pin: I2C_STAT=0
I2C read: I/O error
Unrecognized expansion board: 0
I2C read: I/O error
Die ID #266200040000000004039f220200900f
Net: Net Initialization Skipped
No ethernet found.
The user button is currently NOT pressed.
SD/MMC found on device 0
reading uEnv.txt
** Unable to read “uEnv.txt” from mmc 0:1 **
Loading file “/boot/uImage” from mmc device 0:2 (xxa2)
** File not found /boot/uImage
Booting from nand …
NAND read: device 0 offset 0x280000, size 0x400000
4194304 bytes read: OK
Booting kernel from Legacy Image at 80200000 …
Image Name: Linux-2.6.28-omap1
Data Size: 2577980 Bytes = 2.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
I have tried so many times. But each time it is booting upto here and hanging. I don’t know where i am doing wrong. Can anybody suggest your suggestions…
