I cannot tell the public what I will be using the BBB for but like to know what are power consumption in watts energy? Also what are the design limits in terms of cold and heat? Corrosion resistance? Do the boars also have snap in connectors? I like to know if the board can have a weather seal that will prevent moisture intrusion?
Second question on the Ai board, does it do YOLO vidio processing and what are the limit on image resolution and color? Frame rate processing? Does it run python?
