I am using Beagle Board for project purpose.
I loaded Angstrom/2.6.27 linux in it and I am able to boot it and see
the boot messages on hyperterminal of my PC.
Now , I want to connect it to internet. I have connected a "USB to
ethernet 10/100 adapter" to the beagle board with the use of a "USB
hub 2.0".
Manufacturer of my "USB to ethernet 10/100" is Enter.(http://www.enter-
world.com/).
But when I boot the beagle board(with the above setup), beagle board
is unable to get the ethernet connected. with ifconfig command, it
shows below:
[root@beagleboard /]# ifconfig eth0
ifconfig: eth0: error fetching interface information: Device not found
what may be the issue here,
(1) does beagle board not support this USB to ethernet adapter? if
yes, which one is supported?
(2) Do I need to install a device driver in beagle board to support
this usb to ethernet adapter? if yes, where I can find it in internet?
below is a piece of the message I get on boot.
Texas Instruments X-Loader 1.41
U-Boot 1.3.3 (Jul 10 2008 - 16:33:09)
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Angstrom/2.6.27/beagleboard
Data Size: 2231060 Bytes = 2.1 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Best Regards,
Manish
