We are having a beagle board of revision C3.The spec revels that it
come up with X loader and boot loader u boot.
But when we simply connect to the hyper terminal with proper settings
what we are getting only is the X loader line
why it is not showing the the loading of u boot …???
Do we need to get it boot from the MMC/SD.Yet we will not try
this .since it says that the board comes up with boot loader(u boot)
There could be several reasons for this. It looks to me like the NAND in the board does not have the UBoot in it or that the environment variables have been modified in some way.
Well, per the manual, it says you can plug in both cables at the same time. Plugging in the USB OTG cable and the DC supply will not damage the board.
It does not make sense that only connecting both will give you a proper boot. It should boot using either one unless you have issues with the voltage levels. It sounds to me like you may have a grounding issue with your DC supply and your entire setup. I would make sure that all components in the system are plugged into the same power strip to make sure the grounds are all connected together.
The host USB port on the Beagle is High Speed only. You cannot plug in LS/FS devices, such as keyboards and mice because they will not work. They must be connected through a HS USB HUB first.
I connected the keyboard to the hub that have which is of
USB2.0, and the hub is powered by the usb port in the system
(CPU).The beagle board is also powered to the OTG port from the
hub.Now i am trying the beagle board booting through the hyper
terminal.
But in connecting keyboard in the hub ,cant type anything<root> to get
login.or unable to hit any key to ot interrupt the booting .
The USB EHCI port is not supported in UBoot. It is only supported after the Linux kernel is loaded. You can only use the terminal on the serial port to interrupt the boot process. If it is working, then you should eb able to use the keyboard to login to Linux.
I am confused as to how the HUB is configured in the system. If it is powered by the Beagle, then you can’t power the Beagle via the OTG from the hub. You will have no power.
If the OTG goes to a PC and the hub connects to the Beagle and the keyboard is connected to the HUB, then that will work.
I have a similar issue on BeagleBoard C3. No serial console msg (on minicom) and no USB keyboard and mouse working. The USB HUB power indicators are on and the keyboard blinks while booting, but at the login prompt unable to type anything. Since the serial console also is not working, I am unable to proceed… tried all the ways of powering beagle, but none is working. Beagle boots the OS(tried with Ubuntu18.04 console, Angstrom)
