Hi all,
I have beagle-xm, it is not able to detect the SD card, i have noticed
that the same SD card is working with another beagle-xm, any idea how
can i fix this problem?
Aarti
Hi all,
Aarti
You may have damaged the uSD connector. If that is the case, you will need to get it repaired.
aarti trivedi wrote:
Hi all,
as discussed on irc, RMA the board
check the power supply you are using… if it was more than 5V. the high voltage circuitry might have logged in and red light may be glowing on your board.
If there is a green light with your correct powersupply… then problem with SD port.
If there is a red light on your board. put the right power supply of 5V and try again.
NajmuS
Maybe https://bugs.launchpad.net/linux-linaro/+bug/712175
Cheers,
