beagle bone black is not booting from SD card
while booting the beaglebone black board from SD card, boot process stuck with below errors. what could be the reason?
Terminal ready
U-Boot SPL 2017.03-rc1-dirty (Feb 04 2017 - 17:38:05)
Trying to boot from MMC1
reading u-boot.img
reading u-boot.img
U-Boot 2017.03-rc1-dirty (Feb 04 2017 - 17:38:05 +0530)
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
Using default environment
not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] …
board_rev=[00C0] …
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Bad device 0:2 0x82000000 **
Scanning mmc 0:1…
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
659 bytes read in 18 ms (35.2 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt…
** Invalid partition 3 **
** Invalid partition 4 **
** Invalid partition 5 **
** Invalid partition 6 **
** Invalid partition 7 **
Scanning mmc 1:1…
reading uEnv.txt
26 bytes read in 4 ms (5.9 KiB/s)
Loaded environment from /uEnv.txt
Checking if uenvcmd is set …
Running uenvcmd …
syntax error
syntax error
Checking if client_ip is set …
33 bytes read in 37 ms (0 Bytes/s)
starting USB…
USB0: Port not available.
cpsw Waiting for PHY auto negotiation to complete… TIMEOUT !
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
BOOTP broadcast 18
BOOTP broadcast 19
BOOTP broadcast 20
BOOTP broadcast 21
BOOTP broadcast 22
BOOTP broadcast 23
BOOTP broadcast 24
BOOTP broadcast 25
BOOTP broadcast 26
BOOTP broadcast 27
BOOTP broadcast 28
BOOTP broadcast 29
Retry time exceeded; starting again
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-d0-39-72-97-9f-4d
*** ERROR: serverip' not set Retrieving file: pxelinux.cfg/00000000 cpsw Waiting for PHY auto negotiation to complete......... TIMEOUT ! *** ERROR: serverip’ not set
*** ERROR: serverip' not set Retrieving file: pxelinux.cfg/000000 cpsw Waiting for PHY auto negotiation to complete......... TIMEOUT ! *** ERROR: serverip’ not set
*** ERROR: serverip' not set Retrieving file: pxelinux.cfg/0000 cpsw Waiting for PHY auto negotiation to complete......... TIMEOUT ! *** ERROR: serverip’ not set
*** ERROR: serverip' not set Retrieving file: pxelinux.cfg/00 cpsw Waiting for PHY auto negotiation to complete......... TIMEOUT ! *** ERROR: serverip’ not set
*** ERROR: serverip' not set Retrieving file: pxelinux.cfg/default-arm-am33xx cpsw Waiting for PHY auto negotiation to complete......... TIMEOUT ! *** ERROR: serverip’ not set
*** ERROR: serverip' not set Retrieving file: pxelinux.cfg/default cpsw Waiting for PHY auto negotiation to complete......... TIMEOUT ! *** ERROR: serverip’ not set
Config file not found
Madhu
Hi All,
I could able to boot now from SD card, I fixed it uEnv.txt.
Thank you
Hi Madhu,
what did you change in your uEnv.txt to fix this issue? Thanks you
Hello Madhu,
I am facing similar problem , can you please tell me what you added in uEnv.txt file.
Thank you,
Nilesh Motawala
