Please Give me any hack or debug process to fix booting issue. I’m geeting this issue once I have made a bootable sd card and trying to boot from SD, then facing this issue continuesly. Also tried with S2 for proper boot config for SD card, but till now not getting any clue how its happened.
This is a case where it’s loading MLO but NOT finding the second stage uBoot.img file
isn’t 2019 u-boot a bit old ?
Old - but still good. The old ones are the best!
Do you have any I/O which may be high or low at start up? Some of the boot selection pins are shared with GPIO lines and can cause boot issues.
can you provide which image you used ? is it still on the download site?
Since MLO seems to load but the next stage doesn’t, I wonder if it’s worth checking whether u-boot.img is actually present on the SD card where that image expects it. That might help narrow down whether it’s an image/layout issue or something preventing the bootloader from reading it.
yeah, pleae tell me what I need to do?? sould I need to flash new updated image from beaglebone site??
Normally they are embedded in the base image you flashed? What image or directions are you using? By default they are usually stored inside the MBR of the microSD, so you don’t see them as real files. Instead a block of hex at two separate addresses.
Ignore the italics bit below, I was misremembering how these beagles come up - the uboot stuff at the end is correct though… whats I got wrong, is the below is basically correct - but applied to uboot rather than grub! Anyway should give a way through. Let me know if not clear - if so I’ll just edit this post with all the relevant correct bits in …
Does grub-install work from the command line? I’d have to look how to use it to generate mlo and the secondary boot loader - I haven’t used it in 10 years of so, these days most computers do uefi boot, and that means grub has to install in a particular way, so that’s all I’ve used for years, my old thread on installing arch linux arm on a PB, is probably still valid and will be applicable to BBB. Oh yes one thing to be aware of, grub has grown a lot in size over the years (it now has the basis of land device trees in the code). The beagle family also has its own code in grub, e.g. The beagle has a short string in flash that identifies which variant of beagle is grub running on, grub then selects the right device tree for that beagle. This means the defconfig is now a generic evm if I recall it correctly (that happened 8 or so years ago). Anyway let me look at my old notes, then should be able to reinstall grub from the command line.
Can tell my memory has faded - it’s uboot that needs installing. My old PB thread is Arch Linux ARM • View topic - PocketBeagle on Arch but the defconfig I know has changed since then … Now need to use am335x_evm_defconfig. I wonder if I use grub at all on my beagles farm, or if it does the whole boot using uboot… Yes seems to be uboot: this link gives how to write the mlo and the main uboot: BeagleBone Black | Arch Linux ARM
Yes, but after that as per one training program I have joined, now I have updated the kernel to v6.12.54, then I made one bootable SD, then while booting I’m facing these issue.
yeah but I have checked in the sd card, all the images are present.
Actually the image which was preflashed when I was bought this, but now I’m now updated the kernel to v6.12.54, then I made one bootable SD, then while booting I’m facing these issue.
Nope, Only connected the uart for debug logs, thats it..none of the GPIOs are connected.
