Beagle bone black ubuntu18.04.4 flasher images.
Is there any link to download ubuntu18.04.4 eMMC flasher images. I searched the BeagleBone ubuntu-eLinux.org but they are not available there. On the rcn.ee.com only v20 images are present.
I need the v18 images as my application is designed to run on v18 ubuntu flasher images.
I will have to modify some parts of application if i have to run on v20 ubuntu flasher images.
Any inputs on this will be helpful for me.
I can add this back to the daily feed, but you should also be able to build this on your own…
Probably take 30 minutes on a decent x86…
Edit, and up: Index of /rootfs/ubuntu-bionic-armhf-minimal/2022-07-12
I edited the /boot/uEnv.txt and enabled the eMMC flasher script and did a reset; After that the SD card image got flashed to on Board eMMC chip.
Thanks for guidance.
Thanks for the help.
I tried the images but they boot from SD card directly.
I need Ubuntu v18 eMMC flasher images so that i can directly boot from eMMC chip rather from SD card.
Is is available on rcn.ee link.
Thanks in adavnce.
Hi, these website seems failed today, I wonder wthere to find this old ubuntu img version
I didn’t build 18.04 anymore… Index of /rootfs you can find 20.04 and 22.04
I can see they are all console version, can I remove the console and get a minimal img?
thanks
Pretty much the same thing
okay,thanks!
by the way, can I use toolchain gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf to cross compile thing that can used in this ubuntu system? Thanks
Hi, when I use this ubuntu img with SDcard. it stucks in boot and the debug uart output is as below, how can I fix it? Thank you
U-Boot SPL 2022.04-gbaca7b46 (Jan 15 2024 - 19:59:28 +0000)
Trying to boot from MMC1
U-Boot 2022.04-gbaca7b46 (Jan 15 2024 - 19:59:28 +0000)
CPU  : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM:  512 MiB
RTC 32KCLK Source: External.
Core:  150 devices, 14 uclasses, devicetree: separate
WDT:   Started wdt@44e35000 with servicing (60s timeout)
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net:   eth2: ethernet@4a100000, eth3: usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[00C0] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Couldn't find partition 0:2 0x82000000
Can't set block device
Scanning mmc 0:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk mmc@48060000.blk...
Scanning disk mmc@481d8000.blk...
Found 4 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Checking for: /uEnv.txt ...
Checking for: /boot/uEnv.txt ...
1909 bytes read in 9 ms (207 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-5.10.168-ti-r77 ...
11444736 bytes read in 733 ms (14.9 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/5.10.168-ti-r77/am335x-boneblack-uboot-univ.dtb ...
210706 bytes read in 28 ms (7.2 MiB/s)
Found 0 extension board(s).
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r77/overlays/BB-ADC-00A0.dtbo ...
645 bytes read in 25 ms (24.4 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r77/overlays/BB-BONE-eMMC1-01-00A0.dtbo ...
1605 bytes read in 26 ms (59.6 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r77/overlays/BB-HDMI-TDA998x-00A0.dtbo ...
5321 bytes read in 26 ms (199.2 KiB/s)
loading /boot/initrd.img-5.10.168-ti-r77 ...
11083906 bytes read in 718 ms (14.7 MiB/s)
debug: [console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet] ...
debug: [bootz 0x82000000 0x88080000:a92082 88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0xaea200 ]
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f56d000, end 8ffff082 ... OK
   Loading Device Tree to 8f4d5000, end 8f56cfff ... OK
Starting kernel ...
[    0.174205] l3-aon-clkctrl:0000:0: failed to disable
[   11.038143] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[   11.084243] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'
[   11.084273] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[   11.734466] omap_voltage_late_init: Voltage driver support not added
[   26.602218] systemd[1]: Failed to isolate default target: Unit boot-firmware.mount not found.
[!!!!!!] Failed to isolate default target.
[   26.663825] systemd[1]: Freezing execution.
