I have been having a problem with my beaglebone. It seems to boot, the heartbeat LED is blinking. Everything seems fine, but I can’t ping it.I tried both with the USB cable and the ethernet cable.
What are you connecting the Ethernet cable to? Which Linux distro are you running? If you connect the USB cable to a PC does it show up as a storage device?
If you have connected the ethernet cable between the PC and the BBB that is likely the problem. You need to plug the BBB into a router so it can get an IP address assigned. By default, it is setup to get a dynamic IP address via DHCP.
I have connected the ethernet cable to my network (via router). I’ve assigned a static ip to my BB.
I have connected to the BB via USB as well. Both these IPs are not pingable.
The plug-in a USB cable from your computer into the FTDI board. If you are on windows do this with the device manager open - you will see a new COM port appear. On Windows 8.1 the drivers
Use any terminal program to connect to the serial port with settings 115,200 N81. I use putty pretty much exclusively these days.
Unless you really have a bad board (unlikely) you will connect and an added bonus is that when you reboot the BBB you will see all OS boot messages (dmesg) throughout the boot process.
