Hello Everyone !
Starting a logging thread for beagle-config
Link for proposal - BeagleBoard/GSoC/2021 Proposal/beagle config - eLinux.org
Link for logs - https://satacker.github.io/gsoc-log
Thursday, 20th May#
- Creating a basic menu page(window) for beagle-config
- Forking a process (a simple shell scripting at start)
Tuesday, 25th May#
- Arthur Started a discussion here
- It was decided to make a better and modern looking UI
- Revamped the UI as per suggestions
- Commit for the same can be found here
Sunday, 6th June#
- Revamped the UI with better code (Reduced redundant code)
- Commit for the same can be viewed here
Week 1#
Monday, 7th June#
- The main tasks for this week are
- Introductory Video
- Implement a basic TUI with basic operations like USR LED enable, disable, frequency
- Add
- Network (ICS and Wireless settings)
- ssh configurations
Week 2
Sunday, 13th June#
- Accomplishments :
- Intro Video
- Default ICS
- Route Table default additions using IOCTL calls
- Route Table deletions using IOCTL calls
- Option to input gateways from user
Monday, 14th June#
- Configurations to add
- Wireless
- SSH
- USR Led COnfiguration
- Logging
Week 3
Sunday, 20th June#
- Studied IPC
- Studied DBus
- Implemented hello world with
Connman - Cross compiled dbus
- Blog for the same here
Tuesday, 22nd June#
- Added LED configuration
- Issue : The UI has a broken scrolling
Week 5
Friday, 2nd July#
- Noticed a weird behaviour with
ConnMan - Slack Conversation - Slack
Saturday, 3rd July#
- Flashed a fresh image on beaglebone and surprisingly the interface came back
- Similar Issues - Slack
- One or more services interfere on taking control over Usb Internet
Sunday, 4th July#
- Uninitialized pointer caused infinite loop
- To recognise such errors quickly Arthur (mentor) has added
Address Sanitizeroptions
Monday, 5th July#
Kanban - beagle-config · GitHub
Week 6
Friday, 9th July
Started working on merging feature branches
Worked on implementing code in modular components itself
Sunday, 11th July
Arthur brought in many new features to FTXUI and here as well
USB stopped working on my laptop (both the SS USB ports)
Merged LED branch
Tuesday, 13th July
Sent ICS PR Link
Working on integrating Wireless config in modular components
Week 8
Fri, Jul 23#
- Upstream commit 09714c7a760d77304fc797d8b75e40e633723ab1 - Link
Sunday, Jul 25#
Wireless (#22)
Brings in Wireless feature
- Relies on
connman - Connect
- Disconnect
- List networks
- Lists active network
- Possible issues : Connman may take over some additional services causing undefined behaviour.
- Possible Workarounds / Sol : Add extra functionality to backup resolv.conf and others that can be manipulated by Connman
Fixes:
Mon, Jul 26#
- Better UI for emmc-sd
Tue, Jul 27#
- Grows Partitions too
- Depends on
/opt/scripts/tools/grow_partitions.sh - Removed definitions from
src/utils.hpptosrc/utils.cpp - Demo:
Wed, Jul 28#
Week 9
https://github.com/SAtacker/beagle-config/issues/28
PRU On/Off (#27)
Feature: PRU On/Off
- Tabular UI for PRUSS
- Actions - On/Off
- Info on firmware
Minor: - Removed
scripts/as it’s not needed anymore - Added exit button
- Use Individual PRU.
- Use a class to represent an individual PRU. This lead to simpler and 2x shorter code.
- Moreover, the buttons about a PRU are groups with the info about the PRU.
- It’s time to start documenting which will be done this weekend.
- Until then two simple features of enabling overlay root using cmdline, sensors will be added.
