Dear all,
I have been trying to find information how to use GPIO as input but so
far I have not found anything I could really understand.
Is there a simple way to use BB-XM expansion port GPIO pins in input
mode? Output mode is working easily with echo xxx > export etc...
Best regards,
Mikko
Hello Mikko,
normally, I write a C code setting the GPIOs registers which are
mentioned in Chapter 24 of the "OMAP35xx Applications Processor,
Technical Reference Manual". However, it should also work with a shell
script. I suggest that you take a look in topic 3 of the following
website:
http://bbfordummies.blogspot.com/2009/07/1.html
Best regards,
Frederico
Thank you for answer freddylima & Juha.
> Same sysfs interface works for input:
echo XXX > export ; echo in > gpioXXX/direction ; cat gpioXXX/value
Great, it was easy after all!
As far as I understand the input GPIO external port signal have to be
1.8V, if possible, can you confirm this?
-Mikko
Yes, all the GPIO signals on the expansion header are 1.8V.
Hi Fellows!
I am using the GPIO lines both as outputs and inputs. To convert the levels you have three choices:
- Lowest cost, a resistor divider to convert 5V or 3V3 to 1.8 V in INPUT mode (only).
- A level translator such as TI SN74LCC8T245. 8 lines, all as inputs or outputs at any time.
- “Automatic” translators available from ADI and TI. Each line “knows” its direction.
Pricewise 2 is maybe 5 times the cost of 1 and 3 is double that of 2 - if my memory serves me…
siñ
