I am using a brand new beagleboard-XM, less than a few weeks old.
The boot up messages:
-Boot 2011.03 (Apr 20 2011 - 07:19:53)
OMAP3630/3730-GP ES2.1, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
OMAP3 Beagle board +
LI2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle unknown 0x02
No EEPROM on expansion board
Die ID #776c00029ff800000163810c15028008
Hit any key to stop autoboot: 4
Uncompressing Linux... done, booting the kernel.
fsck from util-linux-ng 2.17.2
/dev/mmcblk0p2: clean, 45725/488640 files, 305044/965908 blocks
* Starting AppArmor
profiles [ OK ]
Ubuntu 11.04 ubuntu ttyO2
The dmesg output is:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.38-8-omap (rsalveti@evatp) (gcc
version 4.5.2 $
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing
instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Reserving 12582912 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630 ES1.2 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x10000
[ 0.000000] On node 0 totalpages: 128000
[ 0.000000] free_area_init_node: node 0, pgdat c077ff00,
node_mem_map c083c0$
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 126976 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pa$
[ 0.000000] Kernel command line: ro elevator=noop vram=12M
omapfb.mode=dvi:1$
Total pa$
omapfb.mode=dvi:1$
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6,
262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072
bytes)
[ 0.000000] allocated 2621440 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't
want memo$
[ 0.000000] Memory: 500MB = 500MB total
[ 0.000000] Memory: 490220k/490220k available, 34068k reserved, 0K
highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xe0800000 - 0xf8000000 ( 376 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0048000 ( 256 kB)
[ 0.000000] .text : 0xc0048000 - 0xc0728680 (7042 kB)
[ 0.000000] .data : 0xc072a000 - 0xc07817a8 ( 350 kB)
[ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0,
CPUs=1, $
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrup$
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns,
wraps every 1$
[ 0.000000] Console: colour dummy device 80x30
[ 0.000122] Calibrating delay loop... 488.41 BogoMIPS (lpj=1908736)
[ 0.140319] pid_max: default: 32768 minimum: 301
[ 0.140472] Security Framework initialized
[ 0.140533] AppArmor: AppArmor initialized
[ 0.140533] Yama: becoming mindful.
[ 0.140808] Mount-cache hash table entries: 512
[ 0.141235] Initializing cgroup subsys ns
[ 0.141235] ns_cgroup deprecated: consider using the
'clone_children' flag w$
[ 0.141265] Initializing cgroup subsys cpuacct
[ 0.141296] Initializing cgroup subsys memory
[ 0.141326] Initializing cgroup subsys devices
[ 0.141357] Initializing cgroup subsys freezer
[ 0.141357] Initializing cgroup subsys blkio
[ 0.141448] CPU: Testing write buffer coherency: ok
[ 0.141693] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver,
5 counte$
[ 0.142547] devtmpfs: initialized
[ 0.144500] print_constraints: dummy:
[ 0.144744] NET: Registered protocol family 16
[ 0.145843] OMAP GPIO hardware version 2.5
[ 0.145935] OMAP GPIO hardware version 2.5
[ 0.145996] OMAP GPIO hardware version 2.5
[ 0.146026] omap_device: omap_gpio.3: new worst case activate
latency 0: 305$
[ 0.146057] OMAP GPIO hardware version 2.5
[ 0.146148] OMAP GPIO hardware version 2.5
[ 0.146209] OMAP GPIO hardware version 2.5
[ 0.147430] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.148529] OMAP3 Beagle Rev: xM C
[ 0.149688] omap_device: omap_uart.1: new worst case activate
latency 0: 305$
[ 0.152404] Found NAND on CS0
[ 0.152404] Registering NAND on CS0
[ 0.152740] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.300018] Switched to new clocking rate (Crystal/Core/MPU):
26.0/332/800 M$
[ 0.300170] OMAP DMA hardware revision 5.0
[ 0.304870] bio: create slab <bio-0> at 0
[ 0.306823] SCSI subsystem initialized
[ 0.307067] libata version 3.00 loaded.
[ 0.307434] usbcore: registered new interface driver usbfs
[ 0.307495] usbcore: registered new interface driver hub
[ 0.307647] usbcore: registered new device driver usb
[ 0.307891] omap_device: omap_i2c.1: new worst case activate
latency 0: 30517
[ 0.319061] omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
latency 0: 30517
[ 0.321289] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.321289] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.321716] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.323699] print_constraints: VUSB1V5: 1500 mV normal standby
[ 0.324096] print_constraints: VUSB1V8: 1800 mV normal standby
[ 0.324462] print_constraints: VUSB3V1: 3100 mV normal standby
[ 0.325988] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 0.326721] print_constraints: VMMC1: 1850 <--> 3150 mV at 3000 mV
normal st$
[ 0.327087] print_constraints: VDAC: 1800 mV normal standby
[ 0.327423] print_constraints: VPLL2: 1800 mV normal standby
[ 0.327819] print_constraints: VSIM: 1800 <--> 3000 mV at 1800 mV
normal sta$
[ 0.338195] omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
[ 0.339019] Advanced Linux Sound Architecture Driver Version
1.0.23.
[ 0.339477] NetLabel: Initializing
[ 0.339508] NetLabel: domain hash size = 128
[ 0.339508] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.339569] NetLabel: unlabeled traffic allowed by default
[ 0.339813] Switching to clocksource 32k_counter
[ 0.344726] Switched to NOHz mode on CPU #0
[ 0.346984] AppArmor: AppArmor Filesystem Enabled
[ 0.357055] musb-hdrc: version 6.0, tusb-omap-dma, otg (peripheral
+host), de$
[ 0.357330] NET: Registered protocol family 2
[ 0.357543] IP route cache hash table entries: 4096 (order: 2,
16384 bytes)
[ 0.358184] TCP established hash table entries: 16384 (order: 5,
131072 byte$
[ 0.358428] TCP bind hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.358581] TCP: Hash tables configured (established 16384 bind
16384)
[ 0.358612] TCP reno registered
[ 0.358612] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.358642] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.358917] NET: Registered protocol family 1
[ 0.358947] NetWinder Floating Point Emulator V0.97 (double
precision)
[ 0.359191] Trying to unpack rootfs image as initramfs...
[ 0.364074] PMU: registered new PMU device of type 0
[ 0.364471] audit: initializing netlink socket (disabled)
[ 0.364532] type=2000 audit(0.437:1): initialized
[ 0.519897] VFS: Disk quotas dquot_6.5.2
[ 0.520233] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 0.523590] fuse init (API version 7.16)
[ 0.524139] msgmni has been set to 957
[ 0.525299] Block layer SCSI generic (bsg) driver version 0.4
loaded (major $
[ 0.525451] io scheduler noop registered (default)
[ 0.525451] io scheduler deadline registered
[ 0.525695] io scheduler cfq registered
[ 0.582397] OMAP DSS rev 2.0
[ 0.582519] OMAP DISPC rev 3.0
[ 0.582550] OMAP VENC rev 2
[ 0.919464] Serial: 8250/16550 driver, 32 ports, IRQ sharing
enabled
[ 0.924468] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a
OMAP UART0
[ 0.924743] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a
OMAP UART1
[ 0.924957] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a
OMAP UART2
[ 0.925109] console [ttyO2] enabled
OMAP UART2
[ 0.925323] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a
OMAP UART3
[ 0.941192] brd: module loaded
[ 0.944519] loop: module loaded
[ 0.949951] i2c-core: driver [adp5520] using legacy suspend method
[ 0.949981] i2c-core: driver [adp5520] using legacy resume method
[ 0.950805] omap2-nand driver initializing
[ 0.951171] No NAND device found.
[ 0.951385] No NAND device found.
[ 0.953063] Fixed MDIO Bus: probed
[ 0.953277] PPP generic driver version 2.4.2
[ 0.953613] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels,
max=256) $
[ 0.953613] CSLIP: code copyright 1989 Regents of the University of
Californ$
[ 0.953613] SLIP linefill/keepalive option.
[ 0.953796] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 2.964874] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 2.973510] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus numb$
[ 2.973632] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
bus numb$
[ 2.988647] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 2.989471] hub 1-0:1.0: USB hub found
[ 2.989501] hub 1-0:1.0: 3 ports detected
[ 3.020324] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.020965] mousedev: PS/2 mouse device common for all mice
[ 3.021667] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 3.027008] Freeing initrd memory: 6248K
[ 3.027099] omap_device: omap_i2c.1: new worst case deactivate
latency 0: 30$
[ 3.027435] omap_device: omap_i2c.1: new worst case activate
latency 0: 61035
[ 3.028198] device-mapper: uevent: version 1.0.3
[ 3.028686] device-mapper: ioctl: 4.19.1-ioctl (2011-01-07)
initialised: dm-$
[ 3.029113] device-mapper: multipath: version 1.2.0 loaded
[ 3.029144] device-mapper: multipath round-robin: version 1.0.0
loaded
[ 3.029754] cpuidle: using governor ladder
[ 3.029785] cpuidle: using governor menu
[ 3.029846] sdhci: Secure Digital Host Controller Interface driver
[ 3.029846] sdhci: Copyright(c) Pierre Ossman
[ 3.137603] OMAP3 Beagle/Devkit8000 SoC init
[ 3.221801] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 3.222564] ALSA device list:
[ 3.222595] #0: omap3beagle
[ 3.223541] TCP cubic registered
[ 3.224395] NET: Registered protocol family 10
[ 3.226074] NET: Registered protocol family 17
[ 3.226226] Registering the dns_resolver key type
[ 3.226287] VFP support v0.3: implementor 41 architecture 3 part 30
variant $
[ 3.227508] omap2_set_init_voltage: unable to find boot up OPP for
vdd_mpu
[ 3.227508] omap2_set_init_voltage: Unable to put vdd_mpu to its
init voltage
[ 3.227539]
[ 3.227874] Power Management for TI OMAP3.
[ 3.228485] clock: disabling unused clocks to save power
[ 3.229553] registered taskstats version 1
[ 3.229736] fbcvt: 1280x720@60: CVT Name - .921M9-R
[ 3.249877] Console: switching to colour frame buffer device 160x45
[ 3.260955] regulator_init_complete: VDAC: incomplete constraints,
leaving on
[ 3.262573] twl_rtc twl_rtc: setting system clock to 2011-09-19
01:53:48 UTC$
[ 3.262908] Freeing init memory: 256K
[ 3.427398] <30>udev[64]: starting version 167
[ 3.558319] mmc0: host does not support reading read-only switch.
assuming w$
[ 3.574462] mmc0: new high speed SDHC card at address b368
[ 3.577331] mmcblk0: mmc0:b368 USD 3.75 GiB
[ 3.582397] mmcblk0: p1 p2
[ 4.948028] Btrfs loaded
[ 5.194061] EXT3-fs: barriers not enabled
[ 5.194854] kjournald starting. Commit interval 5 seconds
[ 5.194915] EXT3-fs (mmcblk0p2): mounted filesystem with ordered
data mode
[ 6.732543] <30>udev[273]: starting version 167
[ 7.486206] Registered led device: beagleboard::usr0
[ 7.491638] Registered led device: beagleboard::usr1
[ 7.504638] Registered led device: beagleboard::pmu_stat
[ 7.505371] input: gpio-keys as /devices/platform/gpio-keys/input/
input0
input0
[ 7.570312] EXT3-fs (mmcblk0p2): using internal journal
[ 7.763641] input: twl4030_pwrbutton as /devices/platform/omap/
omap_i2c.1/i2$
[ 8.075500] omap_device: omap_wdt.-1: new worst case activate
latency 0: 305$
[ 8.144683] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 8.144744] omap_device: omap_wdt.-1: new worst case deactivate
latency 0: 3$
[ 9.579681] type=1400 audit(1316396094.403:2): apparmor="STATUS"
operation="$
[ 9.588989] type=1400 audit(1316396094.411:3): apparmor="STATUS"
operation="$
[ 9.606536] type=1400 audit(1316396094.435:4): apparmor="STATUS"
operation="$
[ 10.674774] type=1400 audit(1316396095.497:5): apparmor="STATUS"
operation="$
[ 10.686614] type=1400 audit(1316396095.513:6): apparmor="STATUS"
operation="$
[ 10.690734] type=1400 audit(1316396095.513:7): apparmor="STATUS"
operation="$
[ 10.731536] type=1400 audit(1316396095.560:8): apparmor="STATUS"
operation="$
[ 62.294219] Adding 524284k swap on /SWAP.swap. Priority:-1 extents:
143 acro$
