Gerald i have BeagleBone LCD3 Cape**,** if i buy BeagleBone Memory Expansion Cape , BeagleBone 4Gb 16-Bit NAND Module and Beaglebone Black can i make it work together.
I want to make BBB boot from emmc and the memory to store data and the micro sd connector to be use for insert card and copy data from them to memory.
Can it be done ?
Valerian.
Currently the SD card is not being recognized, but some people have found a work around for it. The memory expansion module interferes with the eMMC. They use the same pins.
If i use BBW with LCD3 cape and i buy BeagleBone Memory Expansion Cape , BeagleBone 4Gb 16-Bit NAND Module. Can i make the Angstrom to boot from nand memory and use the micro sd connector to add data ?
Valerian.
You should be able to, but it will take a new Uboot to do it.
Gerald if i buy BBB and i add LCD3 Cape Rev A2 will it work.
in the USB slot from BBB can suport memory stick, card reader and extern hard ?
And if i make the sd card connector to work, can i transfer file between sd card and usb ?
i ask if the suport for transfer file is ok implemented?
The problem with sd connector for BBB is solved in last release of software ?
Valerian.
I want to make an storage device for files ?
can i realize this fast ?
Valerian.
if anyone can help me to solve the problem with sd card for BBB ?
and with my application i will be very very grateful.
Valerian.
Let me know when you are stopped sending and I will try and answer your question!
I finish. sorry for this but i don’t have enough time.
Please understand.
Valerian.
Gerald if i buy BBB and i add LCD3 Cape Rev A2 will it work…YES
in the USB slot from BBB can support memory stick, card reader and extern hard ?..Memory stick(Yes), card reader (Yes) HDD, if externally powered.
And if i make the sd card connector to work, can i transfer file between sd card and usb ? …As long as you boot from the SD slot and not eMMC it will work.
i ask if the support for transfer file is ok implemented? …Yes…it is called COPY.
The problem with sd connector for BBB is solved in last release of software ? …NO!
