I am considering using the BeagleBoard as an embedded video player for art installations.
This platform could be a super-valuable tool for this (and other vid artists I’ve talked to agree), where someone who buys a video could have the BB act as a player. The advantage that it has over other players such as the Western Digital HD TV is that it is extremely small and could even be set up to be battery-operated.
I would plan on distributing the video on an SD card along with an Angstrom installation. The customer would then plug in the BB and expect to see a video playing, looped.
There are a few problems, however:
Instead of the BeagleBoard.org splash screen, would there be a way to replace this with a custom splash screen – or even just black?
Is there a way to suprress the Angstrom loading messages?
Finally, a way to automatically login as “root”
After auto-login, I would you want the ability to automatically play a movie via a login script.
In other words, applying power to the beagleboard would boot up the unit (supress the extraneous graphics), login as root (if needed), and call the mplayer command.
Is this possible? And if so, could someone guide me (a non-linux person) through the appropriate steps?
art installations.
artists I've talked to agree), where someone who buys a video could
1. Instead of the BeagleBoard.org splash screen, would there be a way
to replace this with a custom splash screen -- or even just black?
Certainly. Simply removing it is the simplest option, and I'd say
that's good enough considering it won't be spending much time there
anyway.
2. Is there a way to suprress the Angstrom loading messages?
You could use one of the bootsplash-type packages to display a custom
splash screen while the OS boots. I'm afraid I can't comment on the
relative merits of the different flavours.
3. Finally, a way to automatically login as "root"
The simplest option is to launch a player directly from inittab. I've
done this myself for demos.
That's all quite easy to achieve. Think about what functionality
you'd want, and I'm sure someone will be able to assist you.
art installations.
Certainly. Simply removing it is the simplest option, and I’d say
that’s good enough considering it won’t be spending much time there
anyway.
(a) does anyone know the specific steps to remove the BeagleBoard splash screen?
(b) does anyone know how to replace the BB splash screen with my own custom image
splash screen while the OS boots. I’m afraid I can’t comment on the
Can someone direct me to a specific bootsplash-type package that would suppress the Angstrom loading messages? And how to install this?
The simplest option is to launch a player directly from inittab. I’ve
does anyone know how I would specifically modify the inittab file to do an automatic login?
splash screen?
If you interrupt the machine at boot, then you can upload a new
bootsplash image IIRC. You'll need a serial console in order to issue
the required commands. Or, if your u-boot is on the SD card then I
think you can just change the image file there.
custom image
I don't know about Angstrom (I need to look into that I suppose), but
Debian has a "splashy" package that might work. I haven't found a way
to make it work with a raw framebuffer yet, however. I bet Angstrom is
using a similar system just tweaked properly.
Yep. You just clone what the rest of the system startup files are
doing. That's not specific to Beagleboard or Angstrom, it's a Unix thing...
Indeed. If I were to get a second, that's probably about all it would
take...
Thanks for the info. Questions from an inexperienced Linux user (but with experience writing C++ code):
- how do you upload a new bootsplash image IIRC? I can set up a serial console, no problem.
- what *exactly* do you mean by clone what the system startup files are doing? e.g. which files are these. what are they doing?
*or* to everyone, is BeagleBoard only going to be a platform for a very experienced user to work with?
I'll dig my Beagleboard out from the peat on my desk and use it to put
together a procedure for you. Hopefully later this evening.
We can make it as easy or hard as you like.
Seriously, if your Beagleboard is running Debian like mine often do,
then system management issues like causing programs to automatically
start up are handled just like they are on a Debian workstation--- and
are well-documented in Debian System Administration manuals.
I'll put Angstrom back on mine and see what it looks like, but it
probably involves creating a shell script under /etc/init.d, and then
adding a line in /etc/inittab to make the init program launch that shell
script at the right time.
I am trying to solve the same problem. Your work to put this together
would be extremely beneficial to the community. Thanks for offering to
give it a shot.
