Hi all,
I've flashed my recently purchased BBB Rev C to 3.8.13-bone56. Attempted
to use the Logic Supply USB WiFi adapter (UWN200). I've been unable to get
this combination running. I've done nothing but put the appropriate lines
in
/etc/network/interfaces
# WiFi Example
auto wlan0
iface wlan0 inet dhcp
wpa-ssid "WORKSHOP"
wpa-psk "********"
# WiFi Example
#auto ra0
#iface ra0 inet dhcp
# wpa-ssid "WORKSHOP"
# wpa-psk "********"
I've try both wlan0 and ra0, no difference. The USB WiFi adapter is never
detected, dmesg shows no messages indicating it was found.
I do have a Edimax that is working fine, same board same settings (wlan0).
On the package from Logic Supply there is a statement that all drivers are
included with the latest Debian images. What am I missing?
Also with the Edimax, on boot up it connects fine only if there is a
hardwired Ethernet connection. Without the the hardwired Ethernet
connection, the boot time is slow and the wlan0 device never receives a
dhcp address.
And one more thing, is there any settings for power management I need to
take care of (prevent the USB WiFi adapter from going to sleep)?
Thanks for any ideas, help.
Ross
What did you "flash" to your rev C? Out of the box it should have
worked, not all "image" have that driver installed by default..
Dump the response of:
cat /etc/dogtag
Hi all,
Attempted
get this combination running. I've done nothing but put the appropriate
lines in
The latest debian image 3.8.13-bone56
cat /etc/dogtag
No such file or directory
Well, that's odd.. What was the full name of the file you "dd'ed" to
the microSD to flash the eMMC..
Hi all,
Attempted
to get this combination running. I've done nothing but put the
appropriate lines in
cat /etc/dogtag
Don't have that info (workstation at work), but the date was 2014-06-05
and I am unable to find the link where I found it. So, I guess my question
is, what is the latest Debian flasher image and where would I find it.
Hi all,
I’ve flashed my recently purchased BBB Rev C to 3.8.13-bone56.
Attempted
to use the Logic Supply USB WiFi adapter (UWN200). I’ve been unable
to get this combination running. I’ve done nothing but put the
What did you “flash” to your rev C? Out of the box it should have
worked, not all “image” have that driver installed by default…
cat /etc/dogtag
Well, that’s odd… What was the full name of the file you “dd’ed” to
the microSD to flash the eMMC…
Don’t have that info (workstation at work), but the date was 2014-06-05
http://eewiki.net/display/linuxonarm/BeagleBone+Black#BeagleBoneBlack-Debian7
https://rcn-ee.net/deb/flasher/wheezy/
John
Okay, 2014-06-05 didn't have the third party module enabled by
default. (they'll be enabled on my next monthly build)
Open:
/etc/rcn-ee.conf
and add this last line
third_party_modules=enable
Then just rerun:
wget https://rcn-ee.net/deb/wheezy-armhf/v3.8.13-bone56/install-me.sh
sudo /bin/bash install-me.sh
and the module for that device will be added to your bbb.
(reboot)
question is, what is the latest Debian flasher image and where would I
find it.
BBB-eMMC-flasher-debian-7.5-console-2014-06-05-2gb.img.xz
And thank you John Syn for the link to the images. I've made a note of
that URL.
And thank you Robert, I take the following steps to get it going.
Ross
