Disk /dev/mmcblk0: 3965 MB, 3965190144 bytes
255 heads, 63 sectors/track, 482 cylinders, total 7744512 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x000c1e3c
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 * 63 819314 409626 c W95 FAT32 (LBA)
/dev/mmcblk0p2 819315 7743329 3462007+ 83 Linux
When I do boot the device to debian the SD card itself is visible and /media/root and /media/boot seem fine.The problem is if I boot while pressing the boot order toggle button I get nothing. None of the 4 activity LED lights turn on at all. All I see is the power light.
I have a serial cable on order, but in the near term I am trying to diagnose if there is a hardware problem here or if I am doing something wrong.
If I am simply trying to boot from SD card (not flash internal eMMC) is there a length of time I need to hol down the bott order toggle switch? I have tried really short presses as well as upwards of a minute.
I have a similar issue. I have an SD card that boots fine on Rev. B (with Angstrom.) I place the SD card in the slot an it boots from the card! We purchased more BBB Rev. C now (with Dibian), I put the card in and it boots to debian! I need the BBB to boot from SD card. Can anyone shed some light on why Rev. B and Rev. C do not act the same way, and how I can (hopefully modify my SD card to) get Rev. C to boot from the card when it is present.
Rev B's, tried to boot from the microSD, even if that microSD card was blank.
Option 1: blank out the eMMC, then it'll always default to microSD
Option 2: define "uenvcmd" in your uEnv.txt, u-boot will check if this
is set and then runs it via:
(with
We
boots
light
(hopefully
present.
blank.
run uenvcmd;
Assuming you have the latest u-boot on the eMMC, right?
