Beagleboard Booting.
Hi...
While trying to boot beagle board xM is stuck at
[43.658203] usb 2-2.1: New USB device strings: Mfr=0, Product=0,
SerialNumbe0
[43.676727] smsc95xx v1.0.4
And restarts from the begining.... when using the card supplied with
xM......
All the first part are fine including starting of booting....
THE NAME ANGSTROM was supposedto come after this but instead it
reloops....
It sounds like you do not have enough current. Power the board from a 5V 3A power supply. Your power supply does not provide enough current to power up the HUB.
Hey,
I also faced same problem, I used 4.5 V power supply with 800 mA current with all the peripherals connected. It is working fine now.
Hope it helps.
