Hi all,
I'm using Angstrom.
I've installed the battery for the BeagleBoard and removed the R66 as
shown in the manual.
I seen that the first time I boot the board (after installing angstrom
in the SD) the rtc is recognized.
At boot time I can see this:
INIT: version 2.86
booting
Please wait:
booting...
Starting
udev
[ 39.075683] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
and the hwclock command works fine:
root@beagleboard:~# hwclock
Fri Nov 26 16:55:38 2010 0.000000 seconds
but after rebooting the board the rtc0 message disappear:
INIT: version 2.86
booting
Please wait:
booting...
Starting
udev
[ 182.270446] udev: starting version 151
Remounting root file system...
and some row below I see:
hwclock: can't open '/dev/misc/rtc': No such file or directory
Fri Nov 26 16:56:00 UTC 2010
and the hwclock doesn't works:
The only way I have to enable again the rtc is to install Angstrom
again in the SD. But after I reboot the board I have the same problem
again.
Can you help me?
