How can I configure the clock frequency of arm cortex A8 on beagleboard.
I could not find any configuration while building the kernel to do this .
Guys, can anyone please give some inputs on this .
It should be in include/asm-arm/arch-omap3/clocks_omap3.h (u-boot sources)
In menuconfig, look for
SYSTEM TYPE → ENABLE TI OMAP POWER MANAGEMENT → VDD1 OPP
Here we have option to select different OPP/ OMAP MPU frequency.
Shankar
Hi Shankar Ganesh,
I had used that but the mips still showed as 549.xx . It means that it is still running at 550 mhz right ?
Please correct me if I am wrong, How can I verify the speed after choosing the option.
"BogoMips (from "bogus" and MIPS) is an unscientific measurement" - it's not saying anything at all
ok,
But How can I check the processor clock frequency from userspace ?
Hi Shankar Ganesh,
Also refer to /kernel/arch/arm/mach-omap2/clock_34xx.c / .h
Here bogoMIPS = loops per jiffy * No of jiffies in 1 sec * No of million Instruction consumed in delay loop [/init/calibrate.c]
-shankar
Thanks for the help , I managed to reduce the clock frequency by changing the prcm configuration while the kernel is booting .
Is possible to change the clock frequency during the normal system
operation, whithout having to reboot it? Or there is any way to reduce
de power consumption for a while, mantaining the system up and
working?
Thank you.
