On the latest images page(https://beagleboard.org/latest-images) has
the IOT version replaced the plain jane console image? I would really
like to build from the latest basic console image then add options as
needed.
And, how would one go about changing the port nodejs/bonescript listens
on? I would like to get Apache back to port 80 and move
nodejs/bonescript over to port 8080 reversing the way they are
shipped.
Thanks all,
needed.
Have you actually looked ? There is still a console image, and very likely
always will be.
shipped.
There are many ways, including using iptables, or nginx. However, this is
not a question that is specific to this hardware. As such searching the web
for "linux how to change Nodejs port. . ." etc will produce a lot of fruit.
Specifically switching ports on the standard IOT configuration on the
BBGW using the latest IOT image? Any help on that subject?
bonescript: is controlled by a systemd service/socket file, you'll
find port 80 in that..
apache: /etc/apache2/ports.conf you'll find port 8080
Thanks Robert, I'll get the port 80 switched in the bonescript services.
One also needs to change the /sites-enabled/000-default.conf port
number along with the ports.conf for Apache.
Thanks again,
