hi
when i try to install anything with apt-get install ,when the install
is finish i get
udisks depends on libatasmart4 :
packege is not configured yet
udisk depends on udev ;however
package udev is not configured
errors were encountred while processing:
udev
alsa-base
alsa-utils
fuse-utils
libudev0
libgudev-1.0-0
gstreamer0.10-plugins-base
gstreamer0.10-plugins-good
libatasmart4
udisks
libgdu0
gvfs
ntfsprogs
i encountred this problem when i ve triede to install
ap--get install phonon
then i get that error with all packages
2/ to install lucid do i need to add firmware that i ve used with
squeeze
thanks
best regards
Houssem Bahri
hi
is finish i get
udev
alsa-base
alsa-utils
fuse-utils
libudev0
libgudev-1.0-0
libatasmart4
udisks
libgdu0
gvfs
ntfsprogs
Well... try this to cleanup your dpkg stuff...
sudo apt-get clean
sudo apt-get update
then
sudo apt-get install phonon
if IT still fails...   Debian -- Debian BTS - reporting bugs
squeeze
Probably... Why would your device that required firmware all of sudden
not require firmware?
hi
is finish i get
You most likely need to run ‘dpkg-reconfigure udev’ to reconfigure udev for your platform.
Well… try this to cleanup your dpkg stuff…
sudo apt-get clean
sudo apt-get update
then
if IT still fails… http://www.debian.org/Bugs/Reporting
squeeze
I think you’re confusing to OSes here. Lucid Lynx is an Ubuntu operating system. Debian Squeeze is a different operating system. The two OSes will have different packages and dependencies, although they may be very similar they will not be identical. While Ubuntu is based on Debian you’ll likely find that pulling packages from the Debian archive without checking them and re-compiling them first will not work.
