Hi Robert ,
i see that you have made "rebuild-uInitrd.sh" to make a new uInitrd
i used your script the install is good until i get to give my password
and after that i get ###Software selection### : the one selected is
"standard system utilities"
and it started the installation and stopped in 13%
when i reboot my beagleboard i get this
U-Boot 2009.11-00369-ga1b322a (f�évr. 07 2010 -
10:48:28)
OMAP3530-GP ES3.0, CPU-OPP2
L3-165MHz
OMAP3 Beagle board + LPDDR/
NAND
I2C:
ready
DRAM: 256
MB
NAND: 256
MiB
In:
serial
Out:
serial
Err:
serial
Board revision
C
Die ID
#1258000300000000040323090a00300f
Hit any key to stop autoboot:
0
OMAP3 beagleboard.org #
boot
mmc1 is
available
reading
uImage
3239796 bytes
read
reading
uInitrd
2736296 bytes
read
## Booting kernel from Legacy Image at
80000000 ...
Image Name: 2.6.32.11-
x13
Image Type: ARM Linux Kernel Image
(uncompressed)
Data Size: 3239732 Bytes = 3.1
MB
Load Address:
80008000
Entry Point:
80008000
Verifying Checksum ...
OK
## Loading init Ramdisk from Legacy Image at
81600000 ...
Image Name:
initramfs
Image Type: ARM Linux RAMDisk Image
(uncompressed)
Data Size: 2736232 Bytes = 2.6
MB
Load Address:
00000000
Entry Point:
00000000
OK
Loading Kernel Image ...
OK
OK
Starting
kernel ...
Uncompressing
Linux.............................................................
[ 0.000000] Linux version 2.6.32.11-x13 (root@debian-sheevaplug)
(gcc versio0
[ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction ce
[ 0.000000] Machine: OMAP3 Beagle
Board
[ 0.000000] Memory policy: ECC disabled, Data cache
writeback
[ 0.000000] OMAP3430/3530 ES3.0 (l2cache iva sgx neon
isp )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x100000
[ 0.000000] Reserving 14680064 bytes SDRAM for
VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pa4
[ 0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/
mmcblk0p2 o
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096
bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5,
131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.000000] Memory: 128MB 128MB = 256MB
total
[ 0.000000] Memory: 235776KB available (6040K code, 603K data, 184K
init, 0K)
[ 0.000000] Hierarchical RCU
implementation.
[ 0.000000] NR_IRQS:
402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/500
MHz
[ 0.000000] Reprogramming SDRC clock to 332000000
Hz
[ 0.000000] GPMC revision
5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrups
[ 0.000000] Total of 96 interrupts on 1 active
controller
[ 0.000000] OMAP GPIO hardware version
2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768
Hz
[ 0.000000] Console: colour dummy device
80x30
[ 0.000000] Calibrating delay loop... 479.96 BogoMIPS
(lpj=1871872)
[ 0.000000] Security Framework
initialized
[ 0.000000] Smack:
Initializing.
[ 0.000000] Mount-cache hash table entries:
512
[ 0.000000] CPU: Testing write buffer coherency:
ok
[ 0.000000] regulator: core version
0.5
[ 0.000000] NET: Registered protocol family
16
[ 0.000000] Found NAND on
CS0
[ 0.000000] Registering NAND on
CS0
[ 0.000000] Unable to get DVI reset
GPIO
[ 30.042083] OMAP DMA hardware revision
4.0
[ 30.050628] bio: create slab <bio-0> at
0
[ 30.052307] SCSI subsystem
initialized
[ 30.053924] usbcore: registered new interface driver
usbfs
[ 30.054107] usbcore: registered new interface driver
hub
[ 30.054321] usbcore: registered new device driver
usb
[ 30.064605] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600
kHz
[ 30.067443] twl4030: PIH (irq 7) chaining IRQs
368..375
[ 30.067474] twl4030: power (irq 373) chaining IRQs
376..383
[ 30.067810] twl4030: gpio (irq 368) chaining IRQs
384..401
[ 30.069274] regulator: VUSB1V5: 1500 mV normal
standby
[ 30.069549] regulator: VUSB1V8: 1800 mV normal
standby
[ 30.069824] regulator: VUSB3V1: 3100 mV normal
standby
[ 30.073516] twl4030_usb twl4030_usb: Initialized TWL4030 USB
module
[ 30.073944] regulator: VMMC1: 1850 <--> 3150 mV normal
standby
[ 30.074310] regulator: VDAC: 1800 mV normal
standby
[ 30.074645] regulator: VPLL2: 1800 mV normal
standby
[ 30.074951] regulator: VSIM: 1800 <--> 3000 mV normal
standby
[ 30.075134] i2c_omap i2c_omap.2: bus 2 rev3.12 at 400
kHz
[ 30.087127] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100
kHz
[ 30.088439] Bluetooth: Core ver
2.15
[ 30.088684] NET: Registered protocol family
31
[ 30.088684] Bluetooth: HCI device and connection manager
initialized
[ 30.088714] Bluetooth: HCI socket layer
initialized
[ 30.088714] NET: Registered protocol family
8
[ 30.088745] NET: Registered protocol family
20
[ 30.088836] NetLabel:
Initializing
[ 30.088836] NetLabel: domain hash size =
128
[ 30.088867] NetLabel: protocols = UNLABELED
CIPSOv4
[ 30.088958] NetLabel: unlabeled traffic allowed by
default
[ 30.089172] Switching to clocksource
32k_counter
[ 30.090362] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 30.090667] musb_hdrc: USB OTG mode controller at fa0ab000 using
DMA, IRQ 92
[ 30.091278] NET: Registered protocol family
2
[ 30.091522] IP route cache hash table entries: 2048 (order: 1, 8192
bytes)
[ 30.092254] TCP established hash table entries: 8192 (order: 4,
65536 bytes)
[ 30.092498] TCP bind hash table entries: 8192 (order: 3, 32768
bytes)
[ 30.092651] TCP: Hash tables configured (established 8192 bind
8192)
[ 30.092651] TCP reno
registered
[ 30.092956] NET: Registered protocol family
1
[ 30.093505] RPC: Registered udp transport
module.
[ 30.093536] RPC: Registered tcp transport
module.
[ 30.093536] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 30.093933] Trying to unpack rootfs image as
initramfs...
[ 30.416259] Freeing initrd memory:
2672K
[ 30.418518] VFS: Disk quotas
dquot_6.5.2
[ 30.418640] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 30.422821] fuse init (API version
7.13)
[ 30.423980] Btrfs
loaded
[ 30.424011] msgmni has been set to
466
[ 30.426055] alg: No test for stdrng
(krng)
[ 30.426147] io scheduler noop
registered
[ 30.426177] io scheduler anticipatory
registered
[ 30.426177] io scheduler deadline
registered
[ 30.426422] io scheduler cfq registered
(default)
[ 30.487915] OMAP DSS rev
2.0
[ 30.487976] OMAP DISPC rev
3.0
[ 30.488037] OMAP VENC rev
2
[ 30.488342] OMAP DSI rev
1.0
[ 30.756927] musb_hdrc: peripheral reset irq
lost!
[ 30.825500] Serial: 8250/16550 driver, 4 ports, IRQ sharing
enabled
[ 30.846008] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 30.865783] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 30.885498] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 31.396087] console [ttyS2]
enabled
[ 31.407073] brd: module
loaded
[ 31.414031] loop: module
loaded
[ 31.418487] omap2-nand driver
initializing
[ 31.422912] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba
(Micron NAND 2)
modprobe: FATAL: Could not load /lib/modules/2.6.32.11-x13/
modules.dep: No suchy
[ 31.465087] cmdlinepart partition parsing not
available
[ 31.470336] Creating 5 MTD partitions on "omap2-
nand":
[ 31.475585] 0x000000000000-0x000000080000 : "X-
Loader"
[ 31.482055] 0x000000080000-0x000000260000 : "U-
Boot"
[ 31.488586] 0x000000260000-0x000000280000 : "U-Boot
Env"
[ 31.494628] 0x000000280000-0x000000680000 :
"Kernel"
[ 31.501983] 0x000000680000-0x000010000000 : "File
System"
[ 31.610900] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 31.617797] ehci-omap ehci-omap.0: OMAP-EHCI Host
Controller
[ 31.623901] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus numb1
[ 31.631744] ehci-omap ehci-omap.0: irq 77, io mem
0x48064800
[ 31.651855] ehci-omap ehci-omap.0: USB 2.0 started, EHCI
1.00
[ 31.657775] usb usb1: New USB device found, idVendor=1d6b,
idProduct=0002
[ 31.664672] usb usb1: New USB device strings: Mfr=3, Product=2,
SerialNumber1
[ 31.671966] usb usb1: Product: OMAP-EHCI Host
Controller
[ 31.677337] usb usb1: Manufacturer: Linux 2.6.32.11-x13
ehci_hcd
[ 31.683410] usb usb1: SerialNumber: ehci-omap.
0
[ 31.688385] usb usb1: configuration #1 chosen from 1
choice
[ 31.694274] hub 1-0:1.0: USB hub
found
[ 31.698120] hub 1-0:1.0: 3 ports
detected
[ 31.702758] Initializing USB Mass Storage
driver...
[ 31.707885] usbcore: registered new interface driver usb-
storage
[ 31.713928] USB Mass Storage support
registered.
[ 31.718688] g_ether gadget: using random self ethernet
address
[ 31.724609] g_ether gadget: using random host ethernet
address
[ 31.731079] usb0: MAC c2:6f:81:d0:bb:
8f
[ 31.734954] usb0: HOST MAC 26:a6:16:7d:
69:1e
[ 31.739349] g_ether gadget: Ethernet Gadget, version: Memorial Day
2008
[ 31.746032] g_ether gadget: g_ether
ready
[ 31.750061] musb_hdrc musb_hdrc: MUSB HDRC host
driver
[ 31.755615] musb_hdrc musb_hdrc: new USB bus registered, assigned
bus number2
[ 31.763061] usb usb2: New USB device found, idVendor=1d6b,
idProduct=0002
[ 31.769927] usb usb2: New USB device strings: Mfr=3, Product=2,
SerialNumber1
[ 31.777221] usb usb2: Product: MUSB HDRC host
driver
[ 31.782226] usb usb2: Manufacturer: Linux 2.6.32.11-x13 musb-
hcd
[ 31.788299] usb usb2: SerialNumber:
musb_hdrc
[ 31.793182] usb usb2: configuration #1 chosen from 1
choice
[ 31.800201] hub 2-0:1.0: USB hub
found
[ 31.804138] hub 2-0:1.0: 1 port
detected
[ 31.808868] mice: PS/2 mouse device common for all
mice
[ 31.814605] input: gpio-keys as /devices/platform/gpio-keys/input/
input0
[ 31.822692] input: twl4030_pwrbutton as /devices/platform/i2c_omap.
1/i2c-1/11
[ 31.833435] i2c /dev entries
driver
[ 31.838165] OMAP Watchdog Timer Rev 0x31: initial timeout 60
sec
[ 31.949157] Registered led device:
beagleboard::usr0
[ 31.954284] Registered led device:
beagleboard::usr1
[ 31.959899] Registered led device:
beagleboard::pmu_stat
[ 31.965728] Advanced Linux Sound Architecture Driver Version
1.0.21.
[ 31.972686] usbcore: registered new interface driver snd-usb-
audio
[ 31.979064] No device for DAI
twl4030
[ 31.982818] No device for DAI twl4030
Voice
[ 31.987030] No device for DAI omap-mcbsp-
dai-0
[ 31.991577] No device for DAI omap-mcbsp-
dai-1
[ 31.996063] No device for DAI omap-mcbsp-
dai-2
[ 32.000549] No device for DAI omap-mcbsp-
dai-3
[ 32.005035] No device for DAI omap-mcbsp-
dai-4
[ 32.009521] Not OMAP3
EVM!
[ 32.012268] OMAP3 Beagle SoC
init
[ 32.015808] TWL4030 Audio Codec
init
[ 32.021057] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping
ok
[ 32.081665] usb 1-2: new high speed USB device using ehci-omap and
address 2
[ 32.097198] ALSA device
list:
[ 32.100219] #0: omap3beagle
(twl4030)
[ 32.104217] oprofile: using arm/
armv7
[ 32.108276] TCP cubic
registered
[ 32.112243] NET: Registered protocol family
10
[ 32.117675] lo: Disabled Privacy
Extensions
[ 32.122344] NET: Registered protocol family
17
[ 32.126831] NET: Registered protocol family
15
[ 32.131561] Bluetooth: L2CAP ver
2.14
[ 32.135253] Bluetooth: L2CAP socket layer
initialized
[ 32.140411] Bluetooth: SCO (Voice Link) ver
0.6
[ 32.145019] Bluetooth: SCO socket layer
initialized
[ 32.150207] Bluetooth: RFCOMM TTY layer
initialized
[ 32.155181] Bluetooth: RFCOMM socket layer
initialized
[ 32.160400] Bluetooth: RFCOMM ver
1.11
[ 32.164459] ThumbEE CPU extension
supported.
[ 32.168792] Power Management for TI
OMAP3.
[ 32.185150] VFP support v0.3: implementor 41 architecture 3 part 30
variant 1
[ 32.193664] registered taskstats version
1
[ 32.215820] Console: switching to colour frame buffer device
80x30
[ 32.234497] g_ether gadget: high speed config #1: CDC Ethernet
(EEM)
[ 32.247253] regulator_init_complete: incomplete constraints,
leaving VDAC on
[ 32.254699] Freeing init memory:
184K
Loading, please
wait...
[ 32.325927] usb 1-2: New USB device found, idVendor=05e3,
idProduct=0608
[ 32.338226] usb 1-2: New USB device strings: Mfr=0, Product=1,
SerialNumber=0
[ 32.359466] usb 1-2: Product: USB2.0
Hub
[ 32.369659] usb 1-2: configuration #1 chosen from 1
choice
[ 32.386749] hub 1-2:1.0: USB hub
found
[ 32.390930] hub 1-2:1.0: 4 ports
detected
Begin: Loading essential drivers ...
done.
Begin: Running /scripts/init-premount ... [ 32.607513] mmc0: new
high speed S7
[ 32.618988] mmcblk0: mmc0:0007 SD02G 1.81
GiB
[ 32.627532] mmcblk0: p1 p2 p3 < p5
[ 32.699310] usb 1-2.1: new high speed USB device using ehci-omap
and address3
[ 32.971862] usb 1-2.1: New USB device found, idVendor=148f,
idProduct=2573
[ 33.007263] usb 1-2.1: New USB device strings: Mfr=1, Product=2,
SerialNumbe0
[ 33.196472] usb 1-2.1: Product: 802.11 bg
WLAN
[ 33.371063] usb 1-2.1: Manufacturer:
Ralink
[ 33.545837] usb 1-2.1: configuration #1 chosen from 1
choice
done.
Begin: Mounting root file system ... Begin: Running /scripts/local-
top ... done.
Begin: Running /scripts/local-premount ...
done.
[ 33.899902] EXT3-fs: mounted filesystem with writeback data
mode.
[ 33.906158] kjournald starting. Commit interval 5
seconds
Begin: Running /scripts/local-bottom ...
done.
done.
Begin: Running /scripts/init-bottom ...
done.
INIT: version 2.86
booting
Starting the hotplug events dispatcher: udevd[ 35.419433] udev:
starting vers1
Synthesizing the initial hotplug
events...done.
Waiting for /dev to be fully populated...[ 36.956756] cfg80211:
Calling CRDA n
[ 36.981048] twl4030_rtc twl4030_rtc: rtc core: registered
twl4030_rtc as rtc0
[ 37.350250] phy0 -> rt2500usb_init_eeprom: Error - Invalid RT
chipset detect.
[ 37.357666] phy0 -> rt2x00lib_probe_dev: Error - Failed to allocate
device.
[ 37.367309] usbcore: registered new interface driver
rt2500usb
[ 37.728485] Registered led device: rt73usb-
phy1::radio
[ 37.734405] Registered led device: rt73usb-
phy1::assoc
[ 37.740203] Registered led device: rt73usb-
phy1::quality
[ 37.747314] usbcore: registered new interface driver
rt73usb
done.
Activating swap...[ 38.227386] Adding 144376k swap on /dev/
mmcblk0p5. PrioriS
done.
Checking root file system...fsck from util-linux-ng
2.16.2
/dev/mmcblk0p2: Superblock last mount time (Sat Apr 24 18:24:09
2010,
now = Wed Dec 31 18:00:08 1969) is in the
future.
FIXED.
/dev/mmcblk0p2: Superblock last write time (Sat Apr 24 18:24:58
2010,
future.
FIXED.
/dev/mmcblk0p2: clean, 10321/105664 files, 80226/422144 blocks (check
after nex)
done.
[ 38.859405] EXT3 FS on mmcblk0p2, internal
journal
Cleaning up
ifupdown....
Loading kernel
modules...done.
Activating lvm and md
swap...done.
Checking file systems...fsck from util-linux-ng
2.16.2
done.
Setting up
networking....
Mounting local
filesystems...done.
Activating swapfile
swap...done.
Cleaning up temporary
files....
Configuring network
interfaces...done.
Setting kernel
variables ...done.
files....
[ 41.768035] rt73usb 1-2.1:1.0: firmware: requesting
rt73.bin
[ 41.948242] ADDRCONF(NETDEV_UP): wlan0: link is not
ready
INIT: Entering runlevel:
2
Starting enhanced syslogd:
rsyslogd
Warning: Fake start-stop-daemon called, doing
nothing.
Starting periodic command scheduler:
cron
nothing.
best Regards
Houssem Bahri
