In an effort to build an SDCard image for BeagleBoard with
Angstrom/Kernel 3.0 using the OE-core build system, the following
packages have been included in a demo image available for download [3]
and work is in progress to add more:
* gnome
* systemd
* pulseaudio
* alsa
* midori
* gedit
* gstreamer plugins base
* BeagleBoard Test scripts for flashing
* Kernel 3.0.3 including BeagleBoard support and uLCD display patches
Still a very minimal set, but the idea is to get the image out for
users to try out and contribute to.
The image can be downloaded at [3]
Once downloaded, prepare your SDCard by running:
zcat demo-beagleboard-sd-4GiB-r1.img.gz | dd of=/dev/mmcblk0 bs=10M
I have sent several patches to OE-core importing recipes from OE
classic, so any help in that direction is appreciated. The main
recipes for the image are at [1] and [2]
Rebuild Instructions:
You can rebuild the image by following instructions at [4]
With the following differences:
1. Edit layers.txt with:
meta-openembedded,git://github.com/joelagnel/meta-openembedded.git,master,HEAD
meta-angstrom,git://github.com/joelagnel/meta-angstrom.git,master,HEAD
2. Build filesystem using Embedded by running the command:
bitbake beagleboard-validation-gnome-image
3. Using the resultant tar and ubifs found in deploy/ directory, run
this script [5] to build an SDCard image
That should be it.
Looking forward to any feedback and contributions,
Joel
[1] https://github.com/joelagnel/meta-angstrom/blob/master/recipes-angstrom/images/beagleboard-gnome-image.bb
[2] https://github.com/joelagnel/meta-angstrom/blob/master/recipes-angstrom/images/beagleboard-image.bb
[3] http://www.beagleboard.org/~joelf/images/beagleboard-demo/demo-beagleboard-sd-4GiB-r1.img.gz
[4] http://git.angstrom-distribution.org/cgi-bin/cgit.cgi/meta-texasinstruments/plain/README
[5] https://github.com/joelagnel/validation-scripts/blob/master/sdcard-build-scripts/sdcard-create.sh
