I have a working beagleboard XM+SD card, just received it.
I have another beagleboard XM which was not working, I thought it was
the SD card, but the same card that works on one board fails on the
other one (tried this repeatedly), so I think there's some hardware
problem.
The broken one says two type of things:
1.
Texas Instruments X-Loader 1.5.0 (Mar 27 2011 - 17:37:56)
Beagle xM
Reading boot sector
Invalid FAT entry
Loading u-boot.bin from mmc
2.
Beagle xM
Reading boot sector
U-Boot 2011.03-rc1-00000-g9a3cc57-dirty (Apr 01 2011 - 17:41:42)
OMAP3630/3730-GP ES2.1, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev C
No EEPROM on expansion board
Die ID #6b0a00229ff80000016071640d026007
The user button is currently NOT pressed.
SD/MMC found on device 0
** Can't read from device 0 **
** Unable to use mmc 0:1 for fatload **
** Bad partition 2 **
Booting from nand ...
no devices available
Wrong Image Format for bootm command
ERROR: can't get kernel image!
should I file an RMS?
Thanks.
Rodrigo.
