The ROM will work with MLO dumped to sector 0. Don’t know about uboot’s partition support.
It is not true, MLO can be dumped to other sector #. I tried that by creating a win fat32, first partition at sector 2048, 62 sector/track layout, and 512 bytes per sector. I created a native flash builder that does this, any created 50+ images with this CHS layout.
Just because it can be dumped to another sector # does not mean that it
cannot be dumped to 0. Guess that is a language issue.
Is that something you care to share? What is the benefit? This sounds like
it heads right into the problem the thread author was trying to avoid.
My process for the BeagleBoard with x-loader (not BeagleBone and not
current u-boot SPL) is documented at:
https://groups.google.com/d/topic/x-loader/esbsB6PtN8g/discussion
Pretty much the same thing should work with BeagleBone and u-boot SPL.
Other offsets besides 0 are also valid, but the question was about if
u-boot could work with GPT. I did a quick google search and the answer to
that question is yes:
With the ability to boot from sectors rather than a FAT partition plus
u-boot support for GPT, I think the originator of this e-mail thread is in
good shape. As to if Angstrom supports it, well, I don't know that the
Angstrom u-boot is built with GPT support, but reusing the Angstrom kernel
and file system shouldn't be any problem at all.
the first sector of a floppy-like mmc card contains a volume boot sector, similarly, the first sector of a harddrive like mmc card contains a MBR. I dont think loading x-loader to the first sector would work.
What you are saying is that if i were to do this, MLO would get loaded auto-magically!!
dd if=/myMLO of=/dev/sdc bs=512 count=1 # I would be amazed if it worked.
In Omap3730 TRM on section “Device Initialization by ROM Code”, figure 26-26 SD/MMC Booting.
It does not show that the TI Omap bootloader read the first sector and execute the first stage bootloader from there. The diagram shows the flow of validation. If neither MBR or FAT is found on first sector, booting would fail on MMC device completely. Unless this is documented somewhere, I maybe wrong.
This is to proof that the real x-loader (MLO) content lives in cluster# > 2, on a fat32 filesystem. I am sorry if you do not understand my point.
