Hi there,
Could someone point me to some documentation / a tutorial on the
preferred method of building DSP/Link apps inside OpenEmbedded? I've
found http://ossie.wireless.vt.edu/trac/wiki/BeagleBoard_CodecEngine
but thought I'd ask first in case there is something more recent.
I've built the ti-dsplink-module and ti-devshell, just not sure how to
continue with the development. I tried directly make'ing the sample
apps from the ti-devshell script but got make errors. I'd like to
modify the sample DSP/Link apps and re-compile them myself, for
instance.
Yaman
Have a look at the recipes/ti folder, the dsplink recipe and include should show you how to instruct make to use the evironment variables.
regards,
Koen
Hi Yaman,
I have written a wiki to build dsplink outside open-embedded. You can take a look at http://code.google.com/p/opencv-dsp-acceleration/wiki/GettingStarted1 .
To build it inside openembedded, you have to download and save code-generation-tools in the download folder inside OE path and just do ‘bitbake ti-dsplink-module’. If you want to rebuild the examples, you need to do some changes in the make files. You can follow my wiki for that.
Hope that help you.
Be *very* carefull if you go that route. You need to make sure every component matches the one in angstrom, otherwise you'll be chasing unrelated bugs instead of getting gsoc things done. I can speak from experience when I say one can waste weeks due to something like that.
You can take a look at Google Code Archive - Long-term storage for Google Code Project Hosting. .
A quick look at your wiki shows that you are using the wrong versions of:
* cgt
* bios
* xdctools
* codec-engine
Have a look at http://gitorious.org/angstrom/openembedded/blobs/org.openembedded.dev/conf/distro/include/angstrom-codec-engine-2.25.01-preferred-versions.inc to see which versions should be used. This list was compiled with the help of Roger Monk and Chris Ring and works on omap3 and omap-l.
Your dsplink configuro is missing gppos and I stopped reading at that point. Have a look at http://gitorious.org/angstrom/openembedded/blobs/org.openembedded.dev/recipes/ti/ti-dsplink.inc on how to build dsplink without having to edit tons of files.
regards,
Koen
Thanks for the pointer Koen. This was the path I followed earlier before I talked to you on IRC. I now have bitbaked everything and hope it has given me the right versions ie Codec-Engine-2.25.01.06 and all its dependencies.
But still, I have done the modification of the make files according to my wiki to rebuild any changes I do on the examples. Should I not do that way?? I need your suggestion on this.
Regarding the missing gppos on dsplink configuration, isn’t this what you are talking about
# perl dsplinkcfg.pl --platform=OMAP3530 --nodsp=1 --dspcfg_0=OMAP3530SHMEM --dspos_0=DSPBIOS5XX --gppos=OMAPLSP --comps=ponslrmc --DspTskMode=1
I personally dislike editing files and prefer to pass them on the make commandline (e.g. make FOO_DIR=bar), but I can see that people would like to be able to do 'make' and have it work. If you do edit files it is a good idea to use version control on them so you can easily see which changes you made and can show them to others. I tend to delete my sourcetrees more often than my shell history
Regarding the missing gppos on dsplink configuration, isn't this what you are talking about
The gppos indeed and the dsptskmode. I don't know what the taskmode does, but the gppos is the one that will give trouble later on. It's a remnant of the time that every hardware platform (e.g. omap3) only had a single software platfrom (e.g. omaplsp). If someone more familiar with link can shed some light on the dsptskmode switch?
regards,
Koen
