I see...
fdisk -l:
Disk /dev/mmcblk0: 15.9 GB, 15931539456 bytes
Disk /dev/mmcblk1: 1920 MB, 1920991232 bytes
Disk /dev/mmcblk1boot1: 1 MB, 1048576 bytes
Disk /dev/mmcblk1boot0: 1 MB, 1048576 bytes
lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk1boot0 179:16 0 1M 1 disk
mmcblk1boot1 179:24 0 1M 1 disk
mmcblk0 179:0 0 14.9G 0 disk
>-mmcblk0p1 179:1 0 1M 0 part
/home/ubuntu/linux-dev-3.8.13-bone30/depl
`-mmcblk0p2 179:2 0 14.9G 0 part /
mmcblk1 179:8 0 1.8G 0 disk
>-mmcblk1p1 179:9 0 96M 0 part
`-mmcblk1p2 179:10 0 1.7G 0 part
Are you 100% sure, on selecting [/dev/mmcblk0] (y/n)? y
Debug: Existing Partition on drive:
4 heads, 16 sectors/track, 486192 cylinders, total 31116288 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x80008000
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 * 2048 4095 1024 1 FAT12
/dev/mmcblk0p2 4096 31116287 15556096 83 Linux
Unmounting Partitions
Starting Partition Search
Trying: [/dev/mmcblk0p1]
Partition: [/dev/mmcblk0p1] trying: [vfat], [ext4]
Partition: [vfat]
Installing 3.8.13-bone30 to /dev/mmcblk0p1
`/home/ubuntu/linux-dev-3.8.13-bone30/deploy/3.8.13-bone30.zImage' ->
`/home/ubuntu/linux-dev-3.8.13-bone30/deploy/disk/zImage'
cp: writing `/home/ubuntu/linux-dev-3.8.13-bone30/deploy/disk/zImage': No
space left on device
cp: failed to extend
`/home/ubuntu/linux-dev-3.8.13-bone30/deploy/disk/zImage': No space left on
device
In the system.sh file I have set MMC=/dev/mmcblk0
And for your information, I have an expanded file system in which I have
installed ubuntu desktop.
Patches welcome, "armhf.com's" images are not currently supported by my
scripts.
The error is pretty obvious, it clearly shows what branch you need to
checkout to support a specific board.
As to "why" you specifically checked out "stable-kernel.git" git repo.. I
can't explain that. As clearly in all my wiki documentation i reference a
different repo/branch for the beaglebone family.
Worked pretty well actually only for the driver (Linux driver for Netis WF2190) that I am compiling it’s looking for “armv7l” Makefile … I am stuck here. Any idea how to fix this?
make ARCH=armv7l CROSS_COMPILE= -C /lib/modules/3.8.13-bone30/build M=/root/netis-wf2190/driver/rtl8812AU_linux_v4.3.8_12175.20140902 modules
but I get this error: no kernel header package found for 3.8.13-bone84, try another kernel. Before this I had the same error for v3.8.13-bone50. I updated the kernel to v3.8.13-bone84 and now I get this error.
I need to disable interrupts for that I need <asm/system.h> and somewhere I found that I should install linux headers. Could you help me please.
when I do this: sudo apt-get install linux-headers-3.8.13-bone84
I get the following errors:
Reading package lists… Done
Building dependency tree
E: Unable to locate package linux-headers-3.8.13-bone84
E: Couldn’t find any package by regex ‘linux-headers-3.8.13-bone84’
Could you please help me how to instal linux headers for 3.8.13-bone 84 or bone50
Hi Bushra,
Thank you so much.
I performed the steps told by you and I successfully able to install the linux-headers-3.8.13-bone84.But I have one more question that my debian is using linux-headers-3.8.13-bone50 and I am not able to get the headers for it so should I upgrade or downgrade my linux-headers or headers for bone-50 is available?
Can you tell me how install this headers. If you ubuntu-armhf images are not supported by your scripts where can I find the image files support by yours.
done: kernel sources for 3.8.13-bone30 are now installed.
you should be able to compile kernel modules.
But even after this, when I try to compile a module I am not able to it, I get the same error. I have added the snapshots, kindly check and tell me how to solve this.
