BeagleBoard && internet key
Hi all,
I need to use an internet key with beagleboard.
I use Angstrom os created from http://www.angstrom-distribution.org/narcissus/
with included all kernel modules.
Is there a way to use an internet key (usb) that is known by kernel
without external modules?
what internet key do you use?
I use Zyxel G-202. Works out the box.
2010/7/7 luca26 <luca@ventisei.eu>
Hi, thanks,
does it works without need of external driver?
All you need is to set pppd ?
I hope by internet key you mean USB to Wifi adapter.
Dlink products work in my experience.
http://www.unkiddin.com/index.html/images/l_00223295.jpg
-D
No, sorry,
I mean usb modem (hdspa/umts/gsm).
Have a look here:
http://groups.google.com/group/beagleboard/msg/5314603061535756?pli=1
It should work out of the box. No external drivers are required. The
modem will enumerate itself
as a usb serial device /dev/ttyUSBn. You will need some dialer like
wvdial . It should also be possible to configure
using network manager. In ubuntu it should be straight plug and play
-D
what modem are you talking about...?
Guess you mentioned HSDPA Modem in this post. :slight_smile:
I have experience with the Huawei E160 which you get from 3 Mobil
-D
ok thanks :smiley:
Now I'm searching where to buy the Huawei E156g or the E160 in italy
and if possible without block so I can use it with my mobile operator.
