Texas Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24)
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2009.01-rc1-dirty (Aug 13 2009 - 17:27:08)
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
DRAM: 256 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision C
NAND read: device 0 offset 0x280000, size 0x400000
4194304 bytes read: OK
Booting kernel from Legacy Image at 80200000 …
Image Name: Angstrom/2.6.26/beagleboard
Data Size: 2127424 Bytes = 2 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
Uncompressing Linux…
Linux version 2.6.26-omap1 (koen@bitbake) (gcc version 4.2.1) #1 Wed Aug 13 23:8
CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=00c5387f
Machine: OMAP3 Beagle Board
Memory policy: ECC disabled, Data cache writeback
OMAP3430 ES2.3
SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
CPU0: L1 I VIPT cache. Caches unified at level 2, coherent at level 3
CPU0: Level 1 cache is separate instruction and data
CPU0: I cache: 16384 bytes, associativity 4, 64 byte lines, 64 sets,
supports RA
CPU0: D cache: 16384 bytes, associativity 4, 64 byte lines, 64 sets,
supports RA WB WT
CPU0: Level 2 cache is unified
CPU0: unified cache: 262144 bytes, associativity 8, 64 byte lines, 512 sets,
supports WA RA WB WT
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: console=ttyS2,115200n8 console=tty0 root=/dev/mtdblock4 rwf
Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
GPMC revision 5.0
IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP34xx GPIO hardware version 2.5
PID hash table entries: 1024 (order: 10, 4096 bytes)
Console: colour dummy device 80x30
console [tty0] enabled
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 128MB 128MB = 256MB total
Memory: 255360KB available (3876K code, 371K data, 176K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 324 bytes
NET: Registered protocol family 16
Found NAND on CS0
Registering NAND on CS0
OMAP3 L2 cache enabled
Switched to new clocking rate (Crystal/DPLL3/MPU): 26.0/332/166 MHz
OMAP DMA hardware revision 4.0
USB: No board-specific platform config found
i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
i2c_omap i2c_omap.3: bus 3 rev3.12 at 400 kHz
TWL4030: TRY attach Slave TWL4030-ID0 on Adapter OMAP I2C adapter [1]
TWL4030: TRY attach Slave TWL4030-ID1 on Adapter OMAP I2C adapter [1]
TWL4030: TRY attach Slave TWL4030-ID2 on Adapter OMAP I2C adapter [1]
TWL4030: TRY attach Slave TWL4030-ID3 on Adapter OMAP I2C adapter [1]
Initialized TWL4030 USB module
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
musb_hdrc: version 6.0, pio, otg (peripheral+host), debug=0
musb_hdrc: USB OTG mode controller at d0800000 using PIO, IRQ 92
Bluetooth: Core ver 2.11
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 498
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
omapfb: configured for panel omap3beagle
clock: clksel_round_rate_div: dpll4_m4_ck target_rate 108000000
clock: new_div = 4, new_rate = 108000000
omapfb: DISPC version 3.0 initialized
Console: switching to colour frame buffer device 128x48
omapfb: Framebuffer initialized. Total vram 1572864 planes 1
omapfb: Pixclock 54000 kHz hfreq 45.6081 kHz vfreq 57.7 Hz
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
brd: module loaded
loop: module loaded
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
i2c /dev entries driver
TWL4030 GPIO Demux: IRQ Range 384 to 402, Initialization Success
input: triton2-pwrbutton as /class/input/input0
triton2 power button driver initialized
Driver ‘sd’ needs updating - please use bus_type methods
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-b)
cmdlinepart partition parsing not available
Creating 5 MTD partitions on “omap2-nand”:
0x00000000-0x00080000 : “X-Loader”
0x00080000-0x00260000 : “U-Boot”
0x00260000-0x00280000 : “U-Boot Env”
0x00280000-0x00680000 : “Kernel”
0x00680000-0x10000000 : “File System”
TI TSC2102 driver initializing
usbmon: debugfs is not available
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
Initializing USB Mass Storage driver…
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
ether gadget: using random self ethernet address
ether gadget: using random host ethernet address
usb0: Ethernet Gadget, version: May Day 2005
usb0: using musb_hdrc, OUT ep1out IN ep1in STATUS ep2in
usb0: MAC 3e:c6:de:b0:1f:df
usb0: HOST MAC d6:c2:35:7c:24:9f
usb0: RNDIS ready
musb_hdrc musb_hdrc.0: MUSB HDRC host driver
musb_hdrc musb_hdrc.0: new USB bus registered, assigned bus number 2
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
mice: PS/2 mouse device common for all mice
twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0
OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
Bluetooth: HCI USB driver ver 2.9
usbcore: registered new interface driver hci_usb
Bluetooth: Broadcom Blutonium firmware driver ver 1.1
usbcore: registered new interface driver bcm203x
Bluetooth: Digianswer Bluetooth USB driver ver 0.9
usbcore: registered new interface driver bpa10x
Bluetooth: Generic Bluetooth SDIO driver ver 0.1
cpuidle: using governor ladder
cpuidle: using governor menu
Registered led device: beagleboard::usr0
Registered led device: beagleboard::usr1
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.16.
usbcore: registered new interface driver snd-usb-audio
ASoC version 0.13.2
OMAP3 Beagle SoC init
TWL4030 Audio Codec init
asoc: twl4030 <-> omap-mcbsp-dai mapping ok
ALSA device list:
#0: omap3beagle (twl4030)
oprofile: using arm/armv7
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
Bluetooth: L2CAP ver 2.9
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO (Voice Link) ver 0.5
Bluetooth: SCO socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
Bluetooth: BNEP (Ethernet Emulation) ver 1.2
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright © 2004-2005 Intel Corporation <jketreno@linux.intel.com>
ThumbEE CPU extension supported.
Power Management for TI OMAP3.
SmartReflex driver initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
Disabling unused clock “sr2_fck”
Disabling unused clock “sr1_fck”
Disabling unused clock “mcbsp_fck”
Disabling unused clock “mcbsp_ick”
Disabling unused clock “gpt2_ick”
Disabling unused clock “gpt3_ick”
Disabling unused clock “gpt4_ick”
Disabling unused clock “gpt5_ick”
Disabling unused clock “gpt6_ick”
Disabling unused clock “gpt7_ick”
Disabling unused clock “gpt8_ick”
Disabling unused clock “gpt9_ick”
Disabling unused clock “wdt3_ick”
Disabling unused clock “wdt3_fck”
Disabling unused clock “gpt9_fck”
Disabling unused clock “gpt8_fck”
Disabling unused clock “gpt7_fck”
Disabling unused clock “gpt6_fck”
Disabling unused clock “gpt5_fck”
Disabling unused clock “gpt4_fck”
Disabling unused clock “gpt3_fck”
Disabling unused clock “gpt2_fck”
Disabling unused clock “gpt1_ick”
Disabling unused clock “wdt1_ick”
Disabling unused clock “wdt2_ick”
Disabling unused clock “wdt2_fck”
Disabling unused clock “gpt1_fck”
Disabling unused clock “cam_ick”
Disabling unused clock “cam_mclk”
Disabling unused clock “des1_ick”
Disabling unused clock “sha11_ick”
Disabling unused clock “rng_ick”
Disabling unused clock “aes1_ick”
Disabling unused clock “ssi_ick”
Disabling unused clock “mailboxes_ick”
Disabling unused clock “gpt10_ick”
Disabling unused clock “gpt11_ick”
Disabling unused clock “i2c_ick”
Disabling unused clock “mcspi_ick”
Disabling unused clock “hdq_ick”
Disabling unused clock “mspro_ick”
Disabling unused clock “mmchs_ick”
Disabling unused clock “des2_ick”
Disabling unused clock “sha12_ick”
Disabling unused clock “aes2_ick”
Disabling unused clock “icr_ick”
Disabling unused clock “pka_ick”
Disabling unused clock “ssi_ssr_fck”
Disabling unused clock “hdq_fck”
Disabling unused clock “mcspi_fck”
Disabling unused clock “i2c_fck”
Disabling unused clock “mspro_fck”
Disabling unused clock “mmchs_fck”
Disabling unused clock “gpt11_fck”
Disabling unused clock “gpt10_fck”
Disabling unused clock “iva2_ck”
Disabling unused clock “dpll4_m6x2_ck”
Disabling unused clock “dpll4_m5x2_ck”
Disabling unused clock “dpll3_m3x2_ck”
Disabling unused clock “sys_clkout1”
twl4030_rtc twl4030_rtc: setting system clock to 2000-01-01 00:07:01 UTC (94668)
JFFS2 notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsyste.
VFS: Mounted root (jffs2 filesystem).
Freeing init memory: 176K
Warning: unable to open an initial console.
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
sir what will happen if we will erase nand?two of my boards are not working can you help us in this issue?
and the remaining on e board is in this status.can you just tell me what is happening.why is taking from nand?
what is actually happening?it is running this without any card what is the problem?tell me what is the problem?
