Well, we use the serial port to test the board in production so I can only assume it is good, otherwise it would have failed.
Are you setting it to the correct baud rate?
I have not tested that device, so it is not on approved list. This one is however https://www.sparkfun.com/products/9717
Did you check the list of cables before you bought it?
http://circuitco.com/support/index.php?title=BeagleBone_Black_Accessories#Serial_Debug_Cables
Hi Gerald,
Yes, I’m using 115200, 8 bits, No parity, 1 bit stop, No flow control as documented in http://circuitco.com/support/index.php?title=BeagleBone_Black_Accessories
It is the same FTDI 232 chip, just in a different form factor. Since only the ground, rx and tx pins are used, it should make no difference.
Yes, but since I have similar parts laying around from other projects, I did not found it productive to spend another $20 on a cable.
Interestingly enough, hooking up a logic analyzer captured the “- Boot SPL 2013.04-rc1-14237-g90639fe…” text, so the pin seems to be sending the right message…
It is interesting - I tried two different FTDI adapters (the sparkfun and OSEPP-FTDI) and both behaved in the same way: junk on the screen, framing errors…
florin
Sometime the terminal emulators loose their mind. It happens to me often when plugging in the cable. I suggest you plug in the cable and restart the terminal emulator and see if it clears up…
