First of all I am a complete newbie for beagleboard. I have purchased
a new C3 beagleboard and facing issues with it while booting:
1. If try to boot using AC power supply, then there is no prints on
console but board seems to boot as after some time LEDS start glowing.
2. If try to boot using USB power supply then it keeps on printing
'Texas Instruments X-loader ....' continuously.
3. When I tried with pressing USER button while bootup, then also few
U-boot prints followed by CRC error ...
4. I also tried 'pserial' (OMAP utility) to load u-boot.bin image to
board. While file is being getting downloaded 'Texas Instruments X-
loader ....' prints do not appear on board. But immediately after
download completes these prints start coming.
Currently I don't have SD or MMC card and I want to boot u-boot from
UART port.
Am I missing anything here .... or its a hardware issue?
As I don’t have SD and MMC card with me right now. So only option that left for me is booting via UART port.
I was trying recovering procedure as mentioned on:
But ‘ukermit’ failed with following error:
root@chetan-laptop:~/Desktop/boot_omap3_serial# ./ukermit -p /dev/ttyUSB0 -f u-boot.bin
Failed after 4 retries in sequence 0 - success send = 0 bytes
Data transmit failed
I am not able to make any progress so far on this front. Any suggestion would be most welcomed
I would think that this means that the board is ok and you have a u-boot on nand but no image to boot (or maybe a corrupted u-boot). Maybe others can help more but if you can get a SD card i would suggest that you try the full validation -
Ok, I will get a SD card before digging any more into this problem.
Is there any prefrence to SD card and SD card reader for beagleboard?
Chetan Nanda
I always go with a reputable brand for the card, but pretty much any USB reader will do the trick. I personally use SanDisk SD cards, as they’re so cheap in the 2GB and smaller size, and I went with the cheapest SD card reader I could find at a computer swap-meet…
I am having the same issue, I was able to go to the log-in screen but
after entering user name as password, beagle board is printing Texas
Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24) to hyper term.
Finally, I am able to boot my beagleboard and reached upto u-boot prompt.
To sum-up, i face following two problems:
USB OTG cable that I was using earlier has some power drop and, it seems, because of that board is not able to proceed further and keeps printing on console.
‘Texas Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24)’
Hello everyone I am looking for support to flash my board.
I flash a uboot home maid (my the reason why it doesnt' boot
anymore ;)) and I try to get it back !
I am trying the recovery through the UART. I flashed the xloader with
the pserial command
Waiting For Device ASIC ID: Press Ctrl+C to stop
ASIC ID Detected.
Sending 2ndFile:
Downloading file: 100.000% completed(56869/56869 bytes)
File download completed.
but this doesn't work TT
/Bureau/boot_omap3_serial$ ./ukermit -p /dev/ttyUSB0 -f u-boot.bin -d
500
