Its been so very, very long since using linux. I have ubuntu natty installed on my beagleboard and am trying to connect a gsm modem. I appear to have it setup and running using sudo pppd call gsm but after the script finishes I cannot get back to the command prompt. I suspect it is working but I can’t check using ifconfig. Is this because I’m using only a serial console to connect? Is there a way to do this while using the serial console?
for alternatif usage of gsm modem, I can suggest that you can use pppconfig. I use it and to connect modem you write only pon and no need to & char. because it works on backside.
