Thanks for the reply.
How do I enable login via the serial port. I tried putting S:23:respawn:/sbin/getty -L ttyS2 115200 vt100 into /etc/inittab but it did not work.
Also, I tried the DVI+OTG(otg to powered hub to usb keyboard). the dvi worked fine but the keyboard did not. It asked for the root
password to enter maintenance mode to run fsck manually but the keyboard did not respond. Is there any special setup for the keyboard to work?
what am I missing?
Saladino.
