I did these steps to boot the board at u-boot prompt
- mmcinit
- fatload mmc 0:1 0x81600000 ramdisk.gz
- setenv bootargs console=ttyS2,115200n8 console=tty0 root=/dev/ram0 rw ramdisk_size=32768 initrd=0x81600000,32M
and i booted the board by giving the command boot
the booting stoped, here is the log where it is stoped please suggest me to solve this issue.
<6>VFP support v0.3: VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
<6>cpuidle: using governor menu
<5>RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem).
<6>Freeing init memory: 132K
<4>mmc0: host does not support reading read-only switch. assuming write-enable.
<6>mmcblk0: mmc0:0007 SD02G 1955840KiB
<6> mmcblk0: mmcblk0: p1 p1
<6>udevd version 124 started
<3>Buffer I/O error on device mtdblock0, logical block 0
<3>Buffer I/O error on device mtdblock0, logical block 1
<3>Buffer I/O error on device mtdblock0, logical block 2
<3>Buffer I/O error on device mtdblock0, logical block 3
<3>Buffer I/O error on device mtdblock1, logical block 0
<3>Buffer I/O error on device mtdblock1, logical block 1
<3>Buffer I/O error on device mtdblock1, logical block 2
<3>Buffer I/O error on device mtdblock1, logical block 3
<4>timeout waiting for frame-done interrupt
–Sanjeev
a
