Answers to below questions ..
1. 2.6.29-rc8 taken from kernel.org
2. 2.6.22 source taken from http://code.google.com/p/beagleboard/wiki/BeagleSourceCode site ... (I'll assume 'texas' site?)
I did notice the follow string output for the failure case only ...
"usbmon: debugfs is not available"
located directly after ..
Creating 5 MTD partitions on "omap2-nand":
0x000000000000-0x000000080000 : "X-Loader"
0x000000080000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000680000 : "Kernel"
0x000000680000-0x000010000000 : "File System"
.. don't know if this helps.
I patched in the time delay change mentioned below (500 ->5000) with the same problem results.
I'll install 2.6.28-r14 as you noted below & give that a shot.
Thanks a lot for your help !!
regards, Rich..
