Thanks for the suggestion - I gave this distribution a try and had similar
problems. The dongle wouldn't work at all unless an extension cable was in
place. Overall I've been very disappointed in the wireless capabilities of
the current generation BeagleBone. Others have reported that they could get
it working, but I don't have much to show for many frustrating hours spent
looking for a reliable solution. I've got one of the wifi capes on order,
so hopefully that and/or the next generation BeagleBone will be better.FWIW, this Ubuntu distribution gave me the following error on startup when
using the dongle, in spite of having plenty of extra 5V power:[ 2.505512] usb 1-1: rejected 1 configuration due to insufficient
available bus power
fyi: this was just fixed:
just waiting till 3.8.6 drops in a few hours before being sent to the
builders for a *.deb file..
I was able to work around this by doing the following:
echo 1 > /sys/bus/usb/devices/1-1/bConfigurationValue
The dongle then established a wifi connection, but it's not very solid and
seems to drop out after a while. I don't think it's a problem with my
router since both Windows and OSX hosts have no problems using the same
dongle for rock solid connections.I've tried the following two dongles under both Angstrom and Ubuntu and had
the same behavior. One uses the RTL8192 chipset and the other uses the
RTL8188CUS chipset.Intellinet Network Solutions - Provider of PoE and Data Center Product
Intellinet Network Solutions - Provider of PoE and Data Center ProductHas anyone else gotten rock solid wifi connections with the BeagleBone? If
so, what is your exact configuration? Do you use an extension cable?
I've had good luck with Atheros arl9170 based chipsets..
I had an issue with Bluetooth over USB on previous Beaglebone images
(Ubuntu and Angstrom) but a March 28 2013 RCN build using kernel 3.8 fixed
this: http://rcn-ee.net/deb/rootfs/raring/ . You need to specify --uboot
bone_dtb (it's experimental still).
