Hi, I’m trying to boot my beagleboard xm but it keeps rebooting,
I would apreciate some help, following there is the some minicom captures.
Regards
Luis Specian
with ubuntu image:
U-Boot SPL 2011.12-00005-g0a44c98 (Feb 13 2012 - 18:49:45)
Texas Instruments Revision detection unimplemented
OMAP SD/MMC: 0
timed out in wait_for_bb: I2C_STAT=1000
reading u-boot.img
reading u-boot.img
U-Boot 2011.12-00005-g0a44c98 (Feb 13 2012 - 18:49:45)
OMAP3630/3730-GP ES1.1, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev A
No EEPROM on expansion board
Die ID #4fbe00019ff80000015eeaa102008020
Net: Net Initialization Skipped
No ethernet found.
Hit any key to stop autoboot: 2 1 0
The user button is currently NOT pressed.
SD/MMC found on device 0
reading uEnv.txt
761 bytes read
reading uImage
3014528 bytes read
reading uInitrd
3087353 bytes read
Booting from mmc …
Booting kernel from Legacy Image at 80300000 …
Image Name: 3.2.3-x4
Data Size: 3014464 Bytes = 2.9 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading init Ramdisk from Legacy Image at 81600000 …
Image Name: initramfs
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 3087289 Bytes = 2.9 MiB
Load Address: 00000000
Entry Point: 00000000
Loading Kernel Image … OK
OK
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.3-x4 (root@panda-a3-1gb) (gcc version 4.6.1 (Ubuntu/Linaro 4.6.1-9ubuntu3) ) #1 SMP Sat Feb 4 10:33:25 UTC 2012
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Beagle expansionboard: none
[ 0.000000] Beagle second expansionboard: none
[ 0.000000] Reserving 12582912 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630 ES1.1 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/400/600 MHz
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c0d11000 s10784 r8192 d13792 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 125440
[ 0.000000] Kernel command line: console=ttyO2,115200n8 console=tty0 mpurate=auto buddy=none buddy2=none camera=none vram=12MB omapfb.mode=tv:ntsc omapdss.def_disp=tv root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fixrtc
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] allocated 2097152 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.000000] Memory: 494MB = 494MB total
[ 0.000000] Memory: 486984k/486984k available, 37304k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xf8000000 ( 376 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc078814c (7681 kB)
[ 0.000000] .init : 0xc0789000 - 0xc07dea20 ( 343 kB)
[ 0.000000] .data : 0xc07e0000 - 0xc0848c90 ( 420 kB)
[ 0.000000] .bss : 0xc0848cb4 - 0xc090cd50 ( 785 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:410 nr_irqs:410 410
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.000671] Calibrating delay loop… 534.63 BogoMIPS (lpj=2088960)
[ 0.034973] pid_max: default: 32768 minimum: 301
[ 0.035247] Security Framework initialized
[ 0.035308] AppArmor: AppArmor initialized
[ 0.035614] Mount-cache hash table entries: 512
[ 0.036590] Initializing cgroup subsys cpuacct
[ 0.036682] Initializing cgroup subsys memory
[ 0.036743] Initializing cgroup subsys devices
[ 0.036773] Initializing cgroup subsys freezer
[ 0.036773] Initializing cgroup subsys blkio
[ 0.036834] Initializing cgroup subsys perf_event
[ 0.036956] CPU: Testing write buffer coherency: ok
[ 0.037231] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.037872] Brought up 1 CPUs
[ 0.037902] SMP: Total of 1 processors activated (534.63 BogoMIPS).
[ 0.038940] devtmpfs: initialized
[ 0.044860] print_constraints: dummy:
[ 0.045257] NET: Registered protocol family 16
[ 0.045440] GPMC revision 5.0
[ 0.046997] OMAP GPIO hardware version 2.5
[ 0.048706] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.050048] OMAP3 Beagle Rev: xM Ax/Bx
[ 0.053497] Reprogramming SDRC clock to 400000000 Hz
[ 0.053558] dpll3_m2_clk rate change failed: -22
[ 0.055236] Found NAND on CS0
[ 0.055267] Registering NAND on CS0
[ 0.055603] Unable to get DVI reset GPIO
[ 0.055755] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.056488] Could not look up mcpdm hw_mod
[ 0.059722] omap-mcbsp.2: alias fck already exists
[ 0.059906] omap-mcbsp.3: alias fck already exists
[ 0.061248] OMAP DMA hardware revision 5.0
[ 0.069091] bio: create slab at 0
[ 0.070648] SCSI subsystem initialized
[ 0.072052] usbcore: registered new interface driver usbfs
[ 0.072204] usbcore: registered new interface driver hub
[ 0.072418] usbcore: registered new device driver usb
[ 0.073364] omap_i2c omap_i2c.1: bus 1 rev1.4.0 at 2600 kHz
[ 0.076049] twl4030: PIH (irq 7) chaining IRQs 368…375
[ 0.076202] twl4030: power (irq 373) chaining IRQs 376…383
[ 0.076812] twl4030: gpio (irq 368) chaining IRQs 384…401
[ 0.077239] _omap_mux_init_gpio: Could not set gpio192
[ 0.080047] print_constraints: VUSB1V5: 1500 mV normal standby
[ 0.080535] print_constraints: VUSB1V8: 1800 mV normal standby
[ 0.080993] print_constraints: VUSB3V1: 3100 mV normal standby
[ 0.084869] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 0.085754] print_constraints: VMMC1: 1850 <–> 3150 mV at 3150 mV normal standby
[ 0.086273] print_constraints: VDAC: 1800 mV normal standby
[ 0.086730] print_constraints: VDVI: 1800 mV normal standby
[ 0.087249] print_constraints: VSIM: 1800 <–> 3000 mV at 1800 mV normal standby
[ 0.087615] omap_i2c omap_i2c.2: bus 2 rev1.4.0 at 400 kHz
[ 0.097839] omap_i2c omap_i2c.3: bus 3 rev1.4.0 at 100 kHz
[ 0.099212] NetLabel: Initializing
[ 0.099243] NetLabel: domain hash size = 128
[ 0.099273] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.099334] NetLabel: unlabeled traffic allowed by default
[ 0.099395] Switching to clocksource 32k_counter
[ 0.118713] AppArmor: AppArmor Filesystem Enabled
[ 0.133026] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.133697] musb-hdrc musb-hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 0.134124] NET: Registered protocol family 2
[ 0.134552] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.135650] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.136047] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.136383] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.136413] TCP reno registered
[ 0.136444] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.136505] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.136901] NET: Registered protocol family 1
[ 0.137451] RPC: Registered named UNIX socket transport module.
[ 0.137481] RPC: Registered udp transport module.
[ 0.137512] RPC: Registered tcp transport module.
[ 0.137542] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.137969] Trying to unpack rootfs image as initramfs…
[ 0.459075] Freeing initrd memory: 3012K
[ 0.459259] omap_dsp_init: 600000 bytes @ 9ee00000
[ 0.461242] audit: initializing netlink socket (disabled)
[ 0.461334] type=2000 audit(0.468:1): initialized
[ 0.680114] VFS: Disk quotas dquot_6.5.2
[ 0.680664] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.685180] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.685302] fuse init (API version 7.17)
[ 0.687500] Btrfs loaded
[ 0.687561] msgmni has been set to 957
[ 0.689239] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.689270] io scheduler noop registered
[ 0.689300] io scheduler deadline registered
[ 0.689361] io scheduler cfq registered (default)
[ 0.690429] OMAP DSS rev 2.0
[ 0.693695] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.695129] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[ 0.695465] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[ 0.695800] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[ 1.461853] console [ttyO2] enabled
[ 1.465850] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
[ 1.484497] brd: module loaded
[ 1.493011] loop: module loaded
[ 1.499511] twl4030_madc twl4030_madc: clk disabled, enabling
[ 1.507873] omap2-nand driver initializing
[ 1.512542] No NAND device found
[ 1.516326] No NAND device found
[ 1.519989] OneNAND driver initializing
[ 1.524902] usbcore: registered new interface driver cdc_ether
[ 1.531219] usbcore: registered new interface driver rndis_host
[ 1.537567] cdc_ncm: 04-Aug-2011
[ 1.541015] usbcore: registered new interface driver cdc_ncm
[ 1.547546] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.554656] _regulator_get: ehci-omap.0 supply hsusb0 not found, using dummy regulator
[ 1.563140] _regulator_get: ehci-omap.0 supply hsusb1 not found, using dummy regulator
[ 3.584045] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.590393] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 3.598388] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 3.615386] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.621551] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.628784] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.636474] usb usb1: Product: OMAP-EHCI Host Controller
[ 3.642181] usb usb1: Manufacturer: Linux 3.2.3-x4 ehci_hcd
[ 3.648132] usb usb1: SerialNumber: ehci-omap.0
[ 3.653625] hub 1-0:1.0: USB hub found
[ 3.657714] hub 1-0:1.0: 3 ports detected
[ 3.693634] Initializing USB Mass Storage driver…
[ 3.698883] usbcore: registered new interface driver usb-storage
[ 3.705322] USB Mass Storage support registered.
[ 3.710327] usbcore: registered new interface driver libusual
[ 3.716613] udc: OMAP UDC driver, version: 4 October 2004 (iso) (dma)
[ 3.723693] gadget: using random self ethernet address
[ 3.729309] gadget: using random host ethernet address
[ 3.736083] usb0: MAC 9e:ac:c0:87:10:ce
[ 3.740264] usb0: HOST MAC 3a:07:fe:09:1b:d7
[ 3.744781] gadget: Ethernet Gadget, version: Memorial Day 2008
[ 3.751220] gadget: g_ether ready
[ 3.754791] musb-hdrc musb-hdrc: MUSB HDRC host driver
[ 3.760681] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 2
[ 3.768493] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.775756] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.783477] usb usb2: Product: MUSB HDRC host driver
[ 3.788787] usb usb2: Manufacturer: Linux 3.2.3-x4 musb-hcd
[ 3.794769] usb usb2: SerialNumber: musb-hdrc
[ 3.800109] hub 2-0:1.0: USB hub found
[ 3.804168] hub 2-0:1.0: 1 port detected
[ 3.809173] mousedev: PS/2 mouse device common for all mice
[ 3.816345] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input0
[ 3.828430] i2c /dev entries driver
[ 3.832763] Linux media interface: v0.10
[ 3.837158] lirc_dev: IR Remote Control driver registered, major 249
[ 3.844055] Driver for 1-wire Dallas network protocol.
[ 3.850311] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 3.857543] twl4030_wdt twl4030_wdt: Failed to register misc device
[ 3.864135] twl4030_wdt: probe of twl4030_wdt failed with error -16
[ 3.871948] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 3.881469] cpuidle: using governor ladder
[ 3.885742] cpuidle: using governor menu
[ 3.889984] sdhci: Secure Digital Host Controller Interface driver
[ 3.896545] sdhci: Copyright© Pierre Ossman
with test 128 mb sd angstrom:
Texas Instruments X-Loader 1.4.4ss (Aug 19 2010 - 02:49:27)
Beagle xM Rev A
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.03-dirty (Aug 20 2010 - 20:50:46)
OMAP3630/3730-GP ES2.0, CPU-OPP2, L3-165MHz,
I2C: ready
DRAM: 512 MB
NAND: 0 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Probing for expansion boards, if none are connected you’ll see a harmless I2C e.
Beagle xM Rev A
mmc1 is available
reading boot.scr
** Unable to read “boot.scr” from mmc 1:1 **
reading user.scr
755 bytes read
Running bootscript from mmc …
Executing script at 80200000
mmc1 is available
reading ramdisk.gz
